Bigger injectors
Old Jul 18, 2019 | 07:26 AM
kennyG37x's Avatar
kennyG37x
Bigger injectors
Hi all. I recently did some work to my G, I plan on boosting or supercharging soon. So while I had all the intake manifolds off ( which I bored out upper and lower in the process) I switched out the injectors to a bigger size. I got it tuned with ecutek but after it got out of the tune shop I keep throwing a map Sensor code or a vacuum leak. I’ve checked, double checked all the possibilities for a vacuum leak.. My guess would be the car is running to rich. Has anyone had a issue like this or possibly point me in a direction to fix it.. maybe a FPR might help? Any suggestions would help, thanks in advance
Old Jul 18, 2019 | 11:55 AM
SonicVQ's Avatar
SonicVQ
What's the code?
Running rich won't set a MAP code.
Old Jul 18, 2019 | 01:34 PM
kennyG37x's Avatar
kennyG37x
It threw a p0108
Old Jul 18, 2019 | 03:40 PM
kennyG37x's Avatar
kennyG37x
Would you know of a reason why I’m having throttle response issues to where it kinda feels like a limp mode. But it doesn’t happen all the time, and to where it would throw a MAP sensor code or making it dirty to where it won’t run efficiently. I cleaned all the sensors, intake tubes, filters. And it’s somehow still throwing a MAP code.
Old Jul 18, 2019 | 06:21 PM
jpowersjr2's Avatar
jpowersjr2
Contact the shop.
Old Jul 18, 2019 | 06:35 PM
kennyG37x's Avatar
kennyG37x
Originally Posted by jpowersjr2
Contact the shop.
Do you have an idea on what it could be...?
Old Jul 18, 2019 | 07:55 PM
stealthee's Avatar
stealthee
Either its just a coincidence and the sensor failed or the harness got damaged.
Old Jul 18, 2019 | 08:19 PM
kennyG37x's Avatar
kennyG37x
I did happen to change out the sensor before. And it still threw the code. After running for 20-30 minutes it would go into that safe mode or kinda like a limp mode and not give throttle response. I’ll contact the shop see if they could check it out. I put a volt meter on it while I was at the tune shop and it was running high, I believe like 14.5 for the map sensor...
Old Jul 18, 2019 | 08:32 PM
stealthee's Avatar
stealthee
Map sensor should only see 5v if I recall correctly.
Old Jul 18, 2019 | 08:54 PM
kennyG37x's Avatar
kennyG37x
Ya, that’s what I’m sure of as well.. I’m unsure on why it’s running high. And I’m unsure on why it’s getting “dirty” to throw the code
kanji0513
Apr 14, 2011 10:23 PM
MOB
Oct 14, 2010 12:23 AM
SPOHN
Apr 6, 2008 06:59 PM
