Clutch and flywheel question
Old May 7, 2020 | 10:20 AM
jpowersjr2's Avatar
jpowersjr2
That's pretty subjective, because what I'm reading from your comment is, "Mine chatters too."
I never said it didn't. I've heard mine compared to other setups and it's quieter.
Old May 7, 2020 | 10:22 AM
jpowersjr2's Avatar
jpowersjr2
Rochester, I'm iffy on the CMAK. I think the HD CSC would be adequate as long as you aren't seriously increasing clamping force to copper-puck racing levels.
Rethinking my question re: noise above. We used solid unsprung 4-puck copper friction disks, with uprated pressure plates, for the RX7 race cars. They chattered when cold - it was the friction disk stick/unsticking to to the flywheel and pressure plate - but once the car was warmed up they didn't. Clutch engagement was brutal though.
For milder race cars (IT, where the car is mostly stock) we used stock friction disks and an uprated pressure plate (from a B2500 pickup IIRC). They tolerated more shiftor error.
So unless anyone chimes in with it causes damage by doing X, I think this is like the weird blow-off sound you get with HFCs when decelerating - it's a thing, but not that important.
Skip the HD CSC and go with the CMAK. Was just talking to a guy on IG where his just failed. Plus read about others too on the370z.com. I always tell people if they can invest in the CMAK, it's worth the money.
Old May 7, 2020 | 10:33 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
I think the point is that the oem CSC is weak sauce. They make more robust CSCs - that is what the HD kit is. Then again, you'll have the trans out anyway so why not. If you're dropping $1500 on a clutch a few hundred more isn't that big a deal, right?
I am imagining this conversation with my wife and it doesn't go well. For some reason she doesn't trust me to repair the car without (to her) needless upgrades...
Old May 7, 2020 | 10:35 AM
rotarymike's Avatar
rotarymike
Also - yeah, I'm super gentle on the clutch. I don't want to have it fail (I think I just hit 60k miles) and have the damn towtruck driver tear off my front lip to get it home. I've had fails before on standard clutch-fork setups where the slave cyl fails and it will ruin your day.
Old May 7, 2020 | 02:18 PM
RobC7's Avatar
RobC7
Mike, have you ever had your CSC fail on you while driving? It's pretty unnerving. The kind of thing you never forget.
Granted, it's been 6 years later, and the RJM pedal claims to mitigate the underlying design flaw... but still, I think about it in some way every time I drive the car.
I had the Slave cylinder explode in my GTO during a hard 2-3 shift on my way to work. The slave cylinder rattling around in the bellhousing of the trans made it sound like a rod knock, however my fear quickly dissolved when I noticed the clutch pedal stuck to the floor. Definitely something I will never forget.
Thanks for reminding me to order the RJM clutch pedal, really looking forward to that upgrade.
Old Oct 31, 2020 | 04:17 PM
Mike - five months later, where's your head at today on all this?
Rob - did you get that RJM pedal?
Old Nov 1, 2020 | 08:43 AM
rotarymike's Avatar
rotarymike
I think a lightweight flywheel is in my future. I might add some Shockproof to the transmission to cut noise, but you can't go full shockproof or the syncros won't work - they need *some* friction. I'd use a sprung hub street disc and mild pressure plate.
I'm still thinking a beefier all-metal CSC is the way to go. Throwout bearings on clutch fork designs can still go bad and ruin your day - that's what killed my RX8. Throwout seized on the trans shaft, it and the fork bent the crap out of each other, and then it jammed into the clutch fingers. Steady driving on the highway at about 60 to seized drivetrain and frags that cracked the bellhousing. Had to beat it apart with a wood-splitting wedge when we got engine and trans out of the car, and the trans input shaft was toast.
How soon? Anybody's guess. Hell I bought an RJM pedal last year (!) and haven't installed it yet.
Old Nov 1, 2020 | 09:48 AM
Yeah, me too. Still targeting a tune for 2021, so Clutch/FW would be a 2022 mod with parts purchased on Black Friday this time next year.
Low miles, long plans. Not quite as long as your pedal, however...
WTF, man? Slacker.
Old Nov 1, 2020 | 04:42 PM
rotarymike's Avatar
rotarymike
I think since I bought the car May 2018 I've had a total of about 20 hours to work on it. Most of those were over Christmas 2019, installing the full exhaust and incurring the wrath of my wife. I just don't get a lot of free time, and when I do I'm already exhausted from other life stuff. I ain't 20 any more. Or 30. Or 40s for much longer.
The RJM pedal looks like install will take 30 minutes and getting adjusted will take the rest of a 3-day weekend. I just haven't had that amount of time to dedicate to having the car off the road.
Old Nov 6, 2020 | 08:43 AM
projectpanda13's Avatar
projectpanda13
I did a video on my RJM pedal. sadly, i couldn't install mine since i bought the full tilton kit with the master cylinder and wasnt ready to commit to that. But i believe i do throught he process of removing the oem pedal and swapping the sensors.
Old Nov 6, 2020 | 08:50 AM
rotarymike's Avatar
rotarymike
Thanks - I'll check it out. The RJM instructions are actually pretty decent - I've read through them a few times - and removing/replacing the stock clutch pedal assembly doesn't seem too difficult. I did a similar thing in my RX8 after the clutch pedal spot welds snapped (Black Halo Racing Pedal) but that didn't require any adjustment other than the pushrod.
Old Dec 3, 2020 | 04:24 AM
What's gets?'s Avatar
What's gets?
I have a JWT lightweight flywheel in my car with a stock style Z1 clutch kit and honestly it doesn't chatter much at all. Only noticeable sound is when you are stopped in neutral without the clutch pressed in(it kinda sounds like a diesel or a tractor then). I also have the stock pedal assembly and a Z1 CSC elimination kit. Drivability remains the same, but with the revs rising and falling much faster!
Old Dec 3, 2020 | 12:53 PM
rotarymike's Avatar
rotarymike
Sprung hub clutch disc?
Old Dec 3, 2020 | 01:59 PM
  #29
RobC7's Avatar
RobC7
Sorry just seeing this now. I didn't get it but I think about it every now and then. I'll eventually cave in and spend the $300 for it. I'm used to the clutch feel however I know it could be better.
Old Dec 3, 2020 | 02:19 PM
  #30
What's gets?
Yup, standard full face sprung hub disc.
usndocgreen
109
Jan 15, 2019 12:04 AM
awightguy
Jul 7, 2016 05:08 PM
kiernan8585
Oct 5, 2009 11:53 AM
