70K too early for spark plugs?
Old Sep 11, 2017 | 05:30 PM
Victory's Avatar
Victory
Owners manual calls for 100K mi service interval for the iridium plugs, but I do drive quite aggressively. Just noticed over the past few thousand miles that the car doesn't quite feel as sprightly as it used to and I'm not sure what else to look at.
Old Sep 11, 2017 | 05:33 PM
iCrap's Avatar
iCrap
FSM calls for 100k and that's when I did it. The plugs still looked alright when I pulled them out and I didn't notice any difference after anyways. Your problem might be something else.
Old Sep 11, 2017 | 05:44 PM
dkmura's Avatar
dkmura
20 Year Member
Agreed^^ No matter how hard you've pushed your G, unless you've done significant engine modifications it's unlikely the NGKs are the cause. Why not spend some money getting your car on a dyno and getting some baseline figures? That way your butt dyno will never be fooled again, or you can establish some problems.
Old Sep 11, 2017 | 06:06 PM
Victory's Avatar
Victory
did a few 3rd gear pulls with the torque app on and logged some knock events between 2000-4000rpm. Any clues?
Old Sep 12, 2017 | 02:34 AM
takeapieandrun's Avatar
takeapieandrun
Are you using premium gas? And if you're in CA maybe it's because of 91/E15 blend..
Old Sep 12, 2017 | 03:36 AM
crazjayz's Avatar
crazjayz
Try cleaning your throttle bodies. That has been a recurring issue for me once response starts waning.
Old Sep 12, 2017 | 07:52 AM
Vizard_87's Avatar
Vizard_87
I changed mine around 105k miles and they were not bad
Old Sep 12, 2017 | 01:46 PM
Victory's Avatar
Victory
93 octane e10. Top tier. Not the gas. Anyone think it could be false knock from something like a loose heat shield?
Old Sep 12, 2017 | 01:48 PM
Victory's Avatar
Victory
did that about 20-25kmi ago. Time again?
Old Sep 12, 2017 | 07:43 PM
c1utchh's Avatar
c1utchh
Changed mine at 82k on a xS Sedan, to GTR Plugs as recommended by R/T. I don't notice a difference tbh.
Old Sep 12, 2017 | 11:02 PM
Dzionassi's Avatar
Dzionassi
Sebastian@Specialty-Z told me to change plugs 15-20k miles. He see combustion leak by that time....
Old Sep 13, 2017 | 02:21 PM
blazeplacid's Avatar
blazeplacid
Spark plugs every 15-20K sounds like a waste.
Old Sep 13, 2017 | 03:39 PM
iCrap's Avatar
iCrap
Yeah, total waste of money.
Old Sep 15, 2017 | 11:54 AM
tank99's Avatar
tank99
Waste if OEM, but if your running copper's that's about right. Although I don't see as much love for copper here as I did in the Maxima forums.
Old Sep 16, 2017 | 11:02 PM
tdoug's Avatar
tdoug
Replaced mine at 100k....no difference in performance or gas mileage.
