G37 coupe acting up. PLZ HELP
Old May 29, 2018 | 05:44 PM
slartibartfast's Avatar
slartibartfast
^^ You crack me up.
A vacuum line has a vacuum in it, so it will suck in the soapy solution and any bubbles will be inside the line. You might notice a change in idle as the solution covers the hole and improves the vacuum signal, though.
I am not at all ruling out cracked lines, just the soapy water method of locating said cracks.
Old May 29, 2018 | 09:28 PM
kyle_350z's Avatar
kyle_350z
I had the exact same problem. It's kinda dangerous in stop and go traffic when the car wants to lunge forward. Go to the dealer and have them update the ecu software, did that along with throttle body cleaning and it's never come back three years later.
Old May 29, 2018 | 11:56 PM
Ijmv01's Avatar
Ijmv01
Originally Posted by GT97
I seem to be having the same problem. The car continues to lunge forward when braking and idles at about 800 rpm. Have you resolved this issue?
Honestly I took it to the dealer and they Inspected it and told me it was the transmission, and that it would cost 8000 BUCKS to replace it. The weird thing was I’ve been using conventional oil for my G then when I switched to full synthetic it would not happen for a month literally.
Old May 30, 2018 | 03:42 PM
Surfnazi's Avatar
Surfnazi
It works u just need a drop just to help it stick
Old May 30, 2018 | 08:23 PM
saywat?'s Avatar
saywat?
does the blowing smoke into the vacuum hose technique work?
Old May 30, 2018 | 08:38 PM
slartibartfast
^^ Good idea. That's how dealers locate leaks in evap system lines.
Old Jun 4, 2018 | 09:16 PM
spock's Avatar
spock
You aint gonna see bubbles, it'll suck the soap solution in if you have a vacuum leak.
