Who boosts their octane regularly?
Old Aug 21, 2017 | 07:17 PM
Invaderzim's Avatar
Invaderzim
I simply stated my experience. I've ran 91 (ethanol and non blends)92, and 93 octane in my car, switched back and forth to see if I was imagining things, and found that the car runs best on 93. Might just be the gas in my area I suppose, might be my car. Who knows?
Old Aug 21, 2017 | 07:57 PM
kroy's Avatar
kroy
Because 91 is the lowest grade of "premium" fuel
California only has 91. No manufacturer is going to design an engine to run on a grade of gas unavailable in the most populous state in the US.
I don't understand the point you're trying to make.
So you're saying Ferraris are designed to run optimally on 91?
Being able to run on 91 doesn't mean 91 is the optimal fuel. That's my main point.
Ferrari also states: "we recommend that you do not use fuel containing alcohol [i.e., ethanol!] in Ferrari vehicles."
Ferrari wrote this because the fuel we use in the USA isn't the optimal fuel.
Old Aug 21, 2017 | 08:23 PM
Lego_Maniac's Avatar
Lego_Maniac
Are you saying our engine was designed as a high performance engine?
If you think you're car runs better with octane booster, by all means, go for it. I run nothing but 93 in my car.
But our engine isn't a Ferrari. It's part of a larger family of engines:
https://en.wikipedia.org/wiki/Nissan_VQ_engine
I think Nissan optimized our tunes for premium, but I don't think they "designed" it around 93, and then had to scale it back because our gas is crapp* and to make it safe for 91.
If you're looking for proof, I don't think there is any. You can go by what your tuner says, if that makes you happy, but the proof is somewhere in Engineering or R&D at Nissan.
Old Aug 21, 2017 | 08:46 PM
kroy's Avatar
kroy
^ Just using ferrari because it's easier to make the point with a more extreme example.
I think the best way to answer this question is to find out what the Japanese owner's manual says for G37 and 370Z. Having difficulty locating it online though.
