Help Cold Start issue Stillen G37 Coupe
Old Apr 29, 2017 | 11:19 AM
shawnberry45's Avatar
shawnberry45
Hello - G37 Coupe with a stillen supercharger high boost pulley. It currently has a DW300 (G35 style) fuel pump. Runs great when warm started.. starts up on a dime when warm..... but when it's cold... it's like starting up a old car with a carburetor.
Tips or things I can look for? Car runs fantastic when started so bafffles why cold starts are so brutual.
Old Apr 29, 2017 | 03:00 PM
micafd3s's Avatar
micafd3s
check compression...
Old May 1, 2017 | 05:32 AM
Surfnazi's Avatar
Surfnazi
It's your tune i had similar issues
Old May 5, 2017 | 10:27 PM
shawnberry45
With foot off clutch... in "on" position... should fuel pump "prime" each time?
Old May 6, 2017 | 11:17 PM
willstophe's Avatar
willstophe
Are you experiencing long turnover? I am stillen sc myself.
Old May 7, 2017 | 07:14 AM
shawnberry45
Yes... when cold it will not start unless I pump the gas...just like an old carb'd 80's camero lol
sometimes can take 15-20 mins jus to start.
once started everything runs great. Warm starts are flawless.
Plugs? I have the gtr ones in since original install about 2 yrs ago. I've always had this issue tho sadly since installing stillen kit.
Old May 9, 2017 | 03:20 PM
Waste86's Avatar
Waste86
When it starts after turning over a lot I am guessing it kicks out blackish smoke? Cranking enrichment needs to be adjusted in the tune if so. Surfnazi is correct I imagine. The cranking enrichment is a table that varies with coolant temp I believe, which is why it works when it is warm, but not cold. My car has the same issue except it doesn't take as long to start.
Old May 11, 2017 | 06:04 AM
Surfnazi's Avatar
Surfnazi
It's the tune because it's outside the temperature tolerance for cold starts
Either retune it or keep block warmer on car
Old May 16, 2017 | 04:07 PM
shawnberry45
Thanks everyone for all the suggestions! Finally found it.... Turned out to be a vacuum leak from the 3 way plastic connecter that was on the driver side facing the motor, up top. I didn't even notice it because it wasn't even disconnected... just about half way on. I pushed the hose all the way in and put a clamp on it...now it starts ice cold on a dime. It must be connected to the POV, because it seems to be a lot louder now. Running great again.
So strange... Ive been battling this one for almost a year! haha.
