Help I need help! Pleaseeeeeeee
Old Feb 28, 2017 | 06:55 AM
Mattlorentzoe's Avatar
Mattlorentzoe
These are the codes I'm getting? Any thoughts ?
Light came on just after I installed resonated test pipes from fast intentions . I replaced the oxygen sensors at the time of install of test pipes. They are bosch o2 sensors. Could a exhaust leak cause any of these codes?
Old Feb 28, 2017 | 07:33 AM
RMB5190's Avatar
RMB5190
Might be stating he obvious here but have you tried re-setting the ECU so everything can become reacquainted? Might need a re-set to re-learn the new calibrations.
Hopefully someone can chime in who has seen this, but I thought FI were supposed to be CEL free.
Old Feb 28, 2017 | 08:56 AM
The Pope's Avatar
The Pope
Yes, an exhaust leak can cause these and you may also need to mount o2 spacer bung adapters (see Ebay link below) between your o2's and the cats.
2Pack Stainless Steel Universal O2 Sensor Bung Adapter Spacer M18x1.5 x 45mm | eBay
Old Feb 28, 2017 | 04:01 PM
SonicVQ's Avatar
SonicVQ
You could try to put in the OEM A/F sensors, just incase the aftermarket ones are more/less sensitive.
What year is your G?
Old Feb 28, 2017 | 05:07 PM
Upscale Speed's Avatar
Upscale Speed
1. Check for exhaust leaks
2. Use your tuner EcuTek/UpRev cable and program to clear DTC's
3. If those don't work order OEM 02 sensors and return the Bosch ones.
I believe the FI RTP's have a J bung to space away the 02 from the exhaust stream. I know my AAM one's do.
Old Mar 1, 2017 | 06:17 AM
The Pope's Avatar
The Pope
Yes, they have the J bung.
Old Mar 7, 2017 | 08:10 PM
UserNamee's Avatar
UserNamee
I agree with that. Aftermarket parts has disappointed me for too many times.
Old Mar 13, 2017 | 04:52 PM
Mattlorentzoe
How do I reset the ecu or whatever but not loose my uprev tune?
Old Mar 16, 2017 | 06:00 AM
Surfnazi's Avatar
Surfnazi
Unplug battery overnight
