Possible early engine failure smh
Old Apr 1, 2016 | 09:45 AM
dessidee90's Avatar
dessidee90
Noticed about maybe 3-5k ago a slight grinding,chattering sound that found be faintly heard towards the back of the engine, between 1-1.7k rpm. No codes ever been thrown, no lost of performance etc. All fluids are fresh and maintained, oil changed regularly, no oil consumption, premium gas only, and definitely not abused.. Possible oil pressure problems??? I definitely hear it slightly while parked and when going slowly occasionally, not constant while under load. Link below
https://youtu.be/5yK1qkYd-ns
Old Apr 1, 2016 | 10:54 AM
Landshark's Avatar
Landshark
pre-2012?
Old Apr 1, 2016 | 11:04 AM
dessidee90's Avatar
dessidee90
Originally Posted by Landshark
pre-2012?
Yep it's a 2008
Old Apr 1, 2016 | 12:02 PM
Waste86's Avatar
Waste86
Originally Posted by dessidee90
Yep it's a 2008
Landshark was probably hinting at a timing cover gasket failure. Take it to a dealer and have them do an oil pressure test on it. If you wanted to be really sure about it, have them take off the front timing cover and examine the gaskets.
Old Apr 1, 2016 | 12:23 PM
Kris9884's Avatar
Kris9884
Yeah, the more I see these the more I don't want to drive my car lol..
Old Apr 1, 2016 | 12:57 PM
si_driver's Avatar
si_driver
dessidee90,
Sounds exactly like my bad cats sounded at exactly the same RPM range. Dealer replaced under warranty.
I actually went under the car with the engine running to figure out where the noise was coming from. And was sure it was the cats, dealer confirmed and replaced.
Here is my you tube video. (with the cell phone under the car)
Old Apr 1, 2016 | 01:29 PM
rm2342's Avatar
rm2342
hmm, I recently started getting something too, kinda sounds more like an axle, but from time to time I get a faint rattle. Going to have to listen more closely.
What mileage do the cats tend to go? I just flipped past 60k (figures)
Old Apr 1, 2016 | 02:03 PM
Glenn2008's Avatar
Glenn2008
I had some rattling under my car before I replaced my cats with the FI R-HFC's. Now all is well!
Old Apr 1, 2016 | 03:50 PM
Landshark's Avatar
Landshark
if its just the heat shields, a couple bucks worth of large band clamps will fix that.
Old Apr 1, 2016 | 04:36 PM
Victory's Avatar
Victory
Same thoughts. Sounds like a loose heat shield. I don't think your engine is blowing up.
Old Apr 1, 2016 | 06:17 PM
dessidee90's Avatar
dessidee90
Cool thanks for y'all input. I'll do some more investigating, but I was convinced it's from the engine because it's heard at a specific rpm.. hopefully it's just one of the cats, wouldn't it show any symptoms of a bad cat tho?
Old Apr 1, 2016 | 06:31 PM
Landshark's Avatar
Landshark
take a long screwdriver, lay on the ground, and poke at the exhaust heat shields under the car to see if any are loose. had a couple on my other car - they can make a horrible racket when the engine is running, usually at a certain rpm range.
Old Apr 1, 2016 | 08:15 PM
dessidee90's Avatar
dessidee90
Originally Posted by si_driver
dessidee90,
Strange noise at 1000 rpm - YouTube
Yep this is spot on! I'm gonna get mine checked out. Thanks
Old Apr 1, 2016 | 08:23 PM
Landshark's Avatar
Landshark
im sure the dealer would be glad to sell you some expensive new cats, but i'd check to make sure its not just the heat shields ...
Old Apr 2, 2016 | 10:27 AM
si_driver's Avatar
si_driver
My cats started going bad at around 55,000 miles and the dealer replaced them under warranty. There were no issues and/or ECU codes just the noise at 1000-1800 RPMs.
BTW I don't know if everyone knows but the cats have a 8 years and 80K warranty.
Under federal law, the catalytic converter are covered for eight years or 80,000 miles
So don't let Infiniti make you pay for yours if you are still within 8 years and 80K.
