Easy Rear Timing Cover Leak Test?
Old Feb 29, 2016 | 11:25 PM
SonicVQ's Avatar
SonicVQ
I think I have figured out a easy, no tools required way to check for a leaking rear timing cover.
All you need is an OBD-II scanner (I use ELM327 Wi-fi) and an OBD app (Torque or OBD Fusion, or other)
Connect to your car and look at your Mode $06 data, MID / Component ID $35+$36
Here it my data from this Feb 29th:
CID / TID / test result / min / max / pass+fail
$35 - VVT Monitor Bank 1 TID $80 - Manufacturer Defined 3 -13 13 deg Pass
$35 - VVT Monitor Bank 1 TID $82 - Manufacturer Defined -2 -13 13 deg Pass
$36 - VVT Monitor Bank 2 TID $80 - Manufacturer Defined 3 -13 13 deg Pass
$36 - VVT Monitor Bank 2 TID $82 - Manufacturer Defined -1.5 -13 13 deg Pass
If the test result is less than -13 or more than +13, then a check engine light will be either P0011 or P0021.
My thinking is if the test result is around the middle (-5 to 5 or so..) the intake VTC is operating fine. If the VTC is operating fine, it must have the oil pressure it needs.
My ASK:
If possible, post your mode $06 data for item $35/$36. If you happen to have an oil pressure gauge, mention your oil pressure at idle.
I should have my oil pressure sensor gauge installed by next week (as long as the weather is not too cold) and hope to corrolate oil pressure to the test result. OK oil pressure should equal a test result in the middle. Low oil pressure should indicate a value closer to the min or max.
Old Feb 29, 2016 | 11:45 PM
Selym's Avatar
Selym
I'll check mine tomorrow if my app allows. I'm using Blue Driver.
Myles
Old Mar 1, 2016 | 08:54 AM
djdiskino's Avatar
djdiskino
Subscribing for updates and when I drive my G in the spring (hopefully just a month away) I'll post my info as I have the same OBD reader etc.
Old Mar 1, 2016 | 01:53 PM
Selym's Avatar
Selym
2013 G37xS with approx. 27,500 miles, running Infiniti-brand 5w30 (which I believe to be Mobil mineral/synthetic blend)
Immediately After Cold Start in 35°F Ambient Temperature:
ID Value
35 80 1.5°
35 82 -0.5°
36 80 2.5°
36 82 0.5°
After a 12-mile Drive:
ID Value
35 80 2.0°
35 82 -0.5°
36 80 1.5°
36 82 0.5°
Myles
Old Mar 1, 2016 | 03:49 PM
SonicVQ's Avatar
SonicVQ
Do have an oil pressure gauge -or- do you know your oil pressure at idle?
Our numbers are very similar... My oil pressure gauge will be put on when the weather warms up.
Old Mar 1, 2016 | 03:50 PM
Selym's Avatar
Selym
Unfortunately, "no" to both.
Myles
Old Mar 1, 2016 | 03:52 PM
Selym's Avatar
Selym
Does the gauge go in place of the oil pressure switch?
Myles
Old Mar 1, 2016 | 04:06 PM
empirepb48's Avatar
empirepb48
Myles
No, I believe most use a sandwich style plate adapter in between the oil filter male to female threads. From there the adapter allows a tapped hole for the oil pressure sender unit to grab its data.
Would be awesome if this test could prove this out or at least give insight to an issue!
Old Mar 1, 2016 | 05:28 PM
SonicVQ's Avatar
SonicVQ
It is best to have the oil pressure sender/sensor connected to where the oil pressure switch is. This will read the oil pressure AFTER the oil filter.
A pressure gauge connected to a sandwich plate will read the pressure BEFORE the oil filter.
At idle, they should be very close, but at higher RPM, I suspect there will be a 10+ PSI difference. I will be installing 2 pressure sensors (engine port & sandwich plate), to see what the difference is. This may also tell me when the internal oil filter bypass is open, as the pressure before the oil filter will drop when the filter bypass valve opens. (I think!)
GTMTTG37
Apr 12, 2016 08:29 PM
InfinitiG37Ownr
Feb 29, 2016 11:47 AM
g37tx
Feb 1, 2016 06:54 AM
ScrewstonNismo
Motorsports / Track
Jan 28, 2016 05:55 PM
sharmelan
Jan 24, 2016 08:50 PM
