Just did Fast Intentions HFC Install, Have "Service Engine Soon" Keep popping up
Old Dec 1, 2015 | 03:26 PM
NeoNz's Avatar
NeoNz
Originally Posted by m3clubracer
Depending on ?year? of your car:
Pre-cat seems to be Denso
Post cat looks to be Bosch, NTK/NGK
I am assuming your issue is with post cat?
Working with Honda MAP sensors I know that small value changes make things happen you don't want. Same with O2 to a degree.
1. Reset ECU via start button and throttle sequence.
2. If you can get the new cats very hot and burn off any residue etc. with the OE sensors in.
3. Swap out with OEM sensors for that year. Drive and reply.
Some have suggested a re-flash of ecu and that sounds like an expensive and unnecessary option. I hope someone else with experience can chime in also.
If you find out who makes your OE sensor (and year) I would like to know.
Hey
Is the reset ECU via start button throttle sequence different than resetting ECU via 10 hour battery unplug?
I swapped back in the OEM o2 sensors now and ordered Denso O2 sensors set to be delivered tomorrow.
I will apply the Ecu reset via start button tonight and drive around and see what happens.
Hopefully when i install the Denso O2 sensors tomorrow. I will do another ECU reset and let it go.
The guy from rock auto said this is the first return for the NTK (OEM) sensors for this car. I'm not sure what is going wrong, as the car drove fine for 70 miles, then all of the sudden went into shudder mode and just flashed the service engine soon light. barely drove, but 5 seconds before that happened, car would drive fine. I dont get it.
I will hold onto the NTK sensors and see if the Densos are no good tomorrow, i might swap them back in and do the ECU reset via steering wheel again.
I had a shop install the cats, so im assuming there is no leaks, but i will check later, I will also look at the MAF and see if that is on tight no leaks.
Anything else that would help? I ordered a bluetooth OBD2 code reader from amazon so i can check O2 sensor volts, what should those read on a normally functional car?
Thanks again for the help! you are awesome man
Old Dec 1, 2015 | 05:35 PM
m3clubracer's Avatar
m3clubracer
Originally Posted by NeoNz
Hey
>>>It should be the same but it is less of a hassle.
>>>I have no idea at this time. Maybe someone here has the voltages. The FSM may have them also.
>>>YW but lets not go that far!
Old Dec 1, 2015 | 10:18 PM
NeoNz's Avatar
NeoNz
Hey
So i found a vacuum hose not hooked up to my air filter, fixed that, and still the car idles funny and misfires, i can feel it "pop' if i hit the gas.
I did the manual reset, threw in the old OEM o2 sensors but im not sure what is causing the way it runs.
The car ran fine for the first 2 mins when i did the "long reset", once it realized what was wrong, BAM back to square one, same way it drove yesterday with the NTK o2 Sensors. Not really sure what to do at this point
I did another reset and i'll let it sit again. will start it back up. I can tape the idle for you guys if that helps or mimic the noises that happens. I have to really press my footdown on the gas, like its bogging and doesn't want to go anywhere after 2 mins of the reset.
No engine codes, yet, but im sure those are bound to come.
Checked the exhaust bolts for leaks, nothing i could find. re-tightened the intake as well.
please help
Old Dec 2, 2015 | 11:14 AM
m3clubracer
Leaking exhaust should not cause any of this. If it leaks you will see it in the cold and hear it if it is too bad.
You may try one of the 350 or 370 sites as they have more knowledge of these cars. O2 sensor voltages, Did you get the FSM from here?
I am new here and to the car. It sounds like it is running rich or lean for some reason. I tried to read back through all your posts and get the full story like which o2 sensors made it run or not. If in doubt and nothing else works go back to stock. It sucks but it may be the cats. I hope someone else will chime in on the FI cat/o2 code problem.
Old Dec 2, 2015 | 03:00 PM
NeoNz's Avatar
NeoNz
Hey,
I will do my best to start a post on there. Called FI and they believe it is a vacuum leak somewhere. I will start looking around.
Regards,
Brett
Old Dec 3, 2015 | 07:46 AM
m3clubracer
In my limited past experience with these cars a vacuum leak will throw a MAP code (which I get on occasion) not a o2 code. Never found mine. Let me know what you find out.
Old Dec 10, 2015 | 08:11 AM
m3clubracer
Do you still have the CEL?
Old Dec 11, 2015 | 04:16 PM
ANMVQ's Avatar
ANMVQ
I'm wondering the same thing I had a failed header install and the didn't want to drive home CEL light blinking every now and then and misfiring big time . I flashed the car from my one map to stock and did the same thing, did the ecu reset same thing I can't eve start the car goes right into a misfire . Cars been at the dealer for two days and I've heard nothing :/
Old Dec 18, 2015 | 04:20 PM
NeoNz's Avatar
NeoNz
see my other thread, it was a vacuum leak that was causing the misfire, and the blown fuse needed to be changed after the fact. did you fix your car?
Old Dec 19, 2015 | 12:57 PM
m3clubracer
Cool. Since you didn't touch any of the vac lines I guess it is just a coincidence. Where was the leak? Where is your other thread?
Old Dec 19, 2015 | 12:58 PM
NeoNz's Avatar
NeoNz
Midas never secured my intake properly. it fell off about 50 miles after install. then car went crazy limp mode.
Old Dec 19, 2015 | 01:06 PM
m3clubracer
I don't trust anyone to work on my car but me. I have to suck it up on electrical work. Glad to see you got it fixed.
Old Dec 29, 2015 | 11:55 AM
ANMVQ's Avatar
ANMVQ
The dealer tossed in an ECU. Been dealing with a P2A00 code , new sensor and just fixed some exhaust leaks yesterday. We'll see
