which brand engine oil and filter you use for replacement?
Old Sep 29, 2015 | 11:29 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Originally Posted by VIVID
Autozone is currently running a special on the Penn Plat. I'm going with the K&N filter for the M56.
What special? Got a link?
Old Sep 29, 2015 | 11:30 AM
Victory's Avatar
Victory
Originally Posted by chuckie311
i can't understand changing the drain plug every 2 oil changes?
i use a Magnetic Oil Drain Plug for mine..
https://www.z1motorsports.com/engine...ug-p-8226.html
What does that catch that the oil filter won't?
Old Sep 29, 2015 | 03:11 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
it catches any metal that might be floating around if there happens to be any
Old Sep 29, 2015 | 03:33 PM
m3clubracer's Avatar
m3clubracer
The magnetic plug captures particles that would otherwise go through the oil pump. If you have ever seen what these catch you’ll know why it’s a good idea to use one.
Old Sep 30, 2015 | 12:07 AM
lobuzz311's Avatar
lobuzz311
Mobil 1 Synthetic 5w-30 5qt jug
Purolator filter (the longer one)
Fumoto drain valve (with nipple for attaching hose)
Old Sep 30, 2015 | 01:30 AM
604gz's Avatar
604gz
Motul
liqui molly
Definitely the best
Old Oct 1, 2015 | 12:52 AM
VIVID's Avatar
VIVID
Pyroclastic Flow
Deals Engine Oil | AutoZone.com
Sean
Old Oct 1, 2015 | 12:56 AM
VIVID's Avatar
VIVID
Pyroclastic Flow
I've been using copper crush washers on our cars. Works fine, costs virtually nothing for a pack of washers.
Replacing the plug bolt as a matter of maintenance... that doesn't make any sense to me at all.
Same reason as the washer: costs virtually nothing. Then they're nice and clean ready to go. There actually is a schedule for the plug in maintenance. I think it gets changed when the radiator cap gets replaced. If not, I don't care, I like too.
Sean
Old Oct 1, 2015 | 11:02 AM
JSolo's Avatar
JSolo
Just say no!!!!!
This same oil is $25 and change at walmart.
Pennzoil 5W30 Full Synthetic Platinum Motor Oil, 5 qt - Walmart.com
or $28 and change for the ultra platinum.
Pennzoil Ultra Platinum Full Synthetic 5W30 SN Motor Oil, 5 qt - Walmart.com
Old Oct 1, 2015 | 11:36 AM
blueis300's Avatar
blueis300
Dont forget the rebate that I dont see mentioned much. When I used Walmart I still received my rebate.
https://apfco.net/secure/R8235W/Content/OfferForm.pdf
https://apfco.net/secure/R8235W/Home/Entry
Old Oct 1, 2015 | 12:41 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Appears pennzoil has a promo this fall too. $10 MIR.
Pennzoil Coupons and Promotions - Pennzoil
helloandchau
Oct 6, 2015 04:50 PM
stevo4756
Aug 19, 2015 10:14 AM
VRG37S
Aug 18, 2015 09:07 PM
cellwoot
Aug 13, 2015 04:27 PM
