Shudder Noise Low RPM with South Bend Stage 2
I just got my car back today after installing the South Bend Stage 2 kit.
I had the clutch, flywheel, master cylinder, pilot bushing, and zspeed CSC kit installed.
I am experiencing shudder at low RPM in 1st, 2nd, and 3rd gears. Sometimes it's gone though. I only have 20 miles driven on it.
Anyone have more information on this? Read numerous things after doing a quick search.
If it's a NOISE then it's the fact that your flywheel isn't a dual mass flywheel and much lighter than stock. It's unavoidable and there's nothing you can do.
If you mean the car actually shudders then it's something else.
It just seems like a minor shake in the transmission or something? What's the physics behind it? Could you provide a deeper explanation?
The noise is apparently normal. I was told when upgrading from a dual mass fly wheel to a single solid one with an aggressive clutch over OEM produces some chatter. He also told me some technical terms and why it makes the noise, although I don't remember everything he said.
With a stock setup, it is not normal.
Heard back from zspeed performance, and it is indeed normal.
Originally Posted by ZSpeedPerformance
If you are hearing the rattle only down below 2500 rpm or so under load that is normal, Quiet disk won't kill that noise as the floating part is bottomed out under those conditions.
It is normal, I had a JWT lightweight flywheel and it sounded like a cement truck at idle, got used to it and heard it was normal since it wasn't a dual mass flywheel
Only during idle? My noise is only from driving at low rpms in 1st, 2nd and 3rd. It doesn't make the noise during idle.
He has a quiet disk option which gets rid of most of the "noise" (explained as shudder) at idle.
Once you take off and bottom out the floating part of the quiet clutch disk you can sometimes hear it at low rpm (less than 2500rpm) under load as it begins to transfer the engine pulses into the trans at that point.
The noise you get with a single mass flywheel is simply the engine firing pulses getting transmitted into the trans which causes the trans gears to rattle. The South Bend quiet disk acts like the dual mass flywheel at idle to reduce this and works really well but will not get rid of the transfer once you are under load. Once you hit the 2200-2500 rpm mark it goes away.
It is completely normal with a single mass flywheel.
redlinernyc
Feb 29, 2016 11:06 PM
gammamotors
44
Dec 31, 2015 12:48 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
