Need help please
Old Sep 12, 2014 | 12:30 PM
G37 13's Avatar
G37 13
Need help please
I went to a local electric mechanic today and he put on the computer and said these codes came back b1153, b1081, b1134 and said that am missing some wires and it needs to be traced also said that the fan may be the problem for overheating these codes that I have are pertaining to the curtain module, side module, pre tension, just wanted to know if I had my srs module reset already would these modules have to be changed too because I thought that the one under the armrest controlled all of them not sure though
Old Sep 12, 2014 | 11:59 PM
G37 13's Avatar
G37 13
Update 2
Later on in the day I found out it's not the fuse or the module for the fan, it's not getting power from some wires that go to the cooling fan
Old Sep 13, 2014 | 09:26 PM
NetNinja's Avatar
NetNinja
Never mind I see you have another post pertaining to the same issue. I didn't know you were in a crash. Once you get that wire mess fixed you need to put a cover on that to protect your wires.
I thought we had some electrical schematics to figure out what is what?
If you have a smart phone download an App called Torque and get a Bluetooth ELM327 obd2 bluetooth scanner. 3 codes at once may lead to a single culprit like a sensor or maybe the fan is bad?
