BIG mistake with ECU reset!
Old Sep 20, 2012 | 05:46 PM
NyLiGHTz's Avatar
NyLiGHTz
Originally Posted by tomro99
so something else going on? i have also have this problem that i forgot to mention. this happens quite frequently. when i start my G, the rpms barely go over 1000 and then the rpms drop a bit and struggl to stay above the 1000 mark. Right after this, the car shuts off. After i turn the car on and the engine starts, in order for me to keep the engine running, i have to give it gas and then it stays on. But a lot of the time when i dont give it gas, the rpms struggle and the car shuts off.
But even when this was happening, the car still drove like a beast. Its after the ecu reset that the car is feeling very sluggish.
The crappy idle is most likely the throttle bodies. You have to clean them. There's a DiY in the section for it. Lack of power can be too many things.
Old Sep 20, 2012 | 06:23 PM
kaoticdemize's Avatar
kaoticdemize
thats your issue, not the ecm reset, you should have mentioned this in the first place lol. Definately take it in.
Old Sep 20, 2012 | 07:03 PM
tomro99's Avatar
tomro99
Alright well I just finished doing some hard freeway pulls. Responsiveness is better. Acceleration has improved. I guess I just needed to drive it really hard so it could relearn my driving style. I still need to get the rpm issue situated. Gonna take it to my local specialist to do an "relearn" where they clean the throttle bodies etc. thanks for the help guys I really appreciate it!
Old Sep 20, 2012 | 07:04 PM
tomro99's Avatar
tomro99
And my exhaust note is closer to what it was before.
Old Sep 20, 2012 | 07:15 PM
john91's Avatar
john91
I had the same problem when it would shut down on me. My car is at 115k miles , after I cleaned my throttle bodies, the idle performs like from bran new car. I have never had my car shutdown on me by it self after cleaning.
If you want to clean it, please Don't disconnect any cables from the throttle bodies!
Old Sep 20, 2012 | 07:18 PM
tomro99's Avatar
tomro99
Sweet that's good to hear! Thanks man!
Old Sep 20, 2012 | 07:23 PM
hobbs's Avatar
hobbs
Waiting for the ECU to reset . . .
Old Sep 20, 2012 | 09:54 PM
jking's Avatar
jking
How long does it take the car to learn your driving style ?
Old Sep 21, 2012 | 01:05 AM
tomro99's Avatar
tomro99
im not too sure. another member a couple posts back mentioned 50 miles. I just hit the freeway and did about 30 minutes of insane hard pulls in regular mode and M mode. worked well.
Old Sep 21, 2012 | 01:06 AM
tomro99's Avatar
tomro99
i would say drive it hard a couple of days after the reset and it should be good
Old Sep 21, 2012 | 07:59 AM
ashmostro's Avatar
ashmostro
if you haven't heeded the advice of others and cleaned your throttle bodies yet, I would look into that.
Also, make sure your MAF sensor connectors are solidly connected. Your symptoms described earlier point to either or both of the above.
If none of this makes sense to you, take your car in for a diagnostic and let them know the symptoms. You don't want the motor going weak on you in a dangerous situation.
Good luck
Old Sep 21, 2012 | 11:31 PM
htownboy's Avatar
htownboy
Originally Posted by 1BAD2012IPL
Try cleaning the throttle bodies and the mass air flow sensors, the car may be trying to re-learn with these components dirty may be causing the problems you have. Hope this helps
I was about to suggest this when I read this post. This takes care of my issues about every 20,000 miles. Unbelievable how well it runs and how smooth the idle is. The response is noticeably better and the cruise delay in the hills etc is non existent. I also run a good fuel injector cleaner every other month.
Do it, clean the TBI's, add some good FI cleaner and put a few hard driving miles on it before you just go to the dealer.
Old Jul 18, 2019 | 10:17 AM
Roland Rosas's Avatar
Roland Rosas
I agree
I dont know for sure but i agree. Try cleaning the Mass air flow sensors dude.
Old Jul 18, 2019 | 10:28 AM
  #29
ILM-NC G37S's Avatar
ILM-NC G37S
I am quite sure that after almost 7 years the issues have long since been resolved- especially since the OP and most of the other users haven't been on the forum in years...
Another dead thread brought back from the digital abyss...
Old Jul 19, 2019 | 08:18 PM
  #30
saywat?'s Avatar
saywat?
brought back from the fine residents of noobsville lol
