Starting steps
Old Jul 11, 2012 | 02:27 PM
ANMVQ's Avatar
ANMVQ
Starting steps
Ok so some of you know about my SC taking a dump, Stillen is going to warrenty it, But I'm still thinking about making some changes. I "MAY" or "MAY not" Send it to 928 Motorsports for the Impeller upgrade but either way I see in the future me adding something for more HP. We all have heard the rummors about the heat soak issue the Stillen kit has in the summer, So I went ahead and grabbed a upgraded heat exchanger from Frozenboost.com. Lots of american guys run these, SVT mustangs, Lightings and a few SC Camaros, The price was really good , Under $170 shipped and pretty big at 26x7x3.5.
Air to Water Heat Exchanger
Old Jul 11, 2012 | 03:58 PM
Weiboy718's Avatar
Weiboy718
I hope you ordered the exchanger with the inlet on one side then the outlet on the other. If both on same side you may need to buy new hoses and reroute the coolant lines. Making the bracket shouldn't be too hard and mount it behind the crash bar but you might have to mount your oil cooler else where and with your car being an 2011 with bumper fog lights it's kinda hard finding another location. You have the 19 or 25 row oil cooler?
Old Jul 11, 2012 | 04:52 PM
ANMVQ's Avatar
ANMVQ
Hey Wieboy, NA there both on the same side The new 5/8 hose are no problem, I looked in there I have room , the oil cooler is the 19 row I think.,
Old Jul 11, 2012 | 05:25 PM
Weiboy718's Avatar
Weiboy718
Well can't wait to see your final product then. When I was running the STILLEN kit I was looking at the same setup too but never happened because my car never ran correctly.
Also keep in mind if you install this in front of the oil cooler you need to watch your oil temps as air flow would be drastically reduced from going in there.
Good luck bud!
Old Jul 11, 2012 | 09:59 PM
ANMVQ's Avatar
ANMVQ
Thanx man will be next to the oil cooler , Will do gonna see if I can get some install pics, we'll see
Old Jul 12, 2012 | 08:38 AM
ANMVQ's Avatar
ANMVQ
I also looked at the Stillen Exchanger and the in and out are on the same side, So really should'nt be anything other than getting the brackets to work.
Old Jul 12, 2012 | 09:17 AM
ANMVQ's Avatar
ANMVQ
What is the benifit of a larger Supercharger coolant tank, Just that more coolant to flow would keep it cooler, I know it sounds dumb, But more to flow through the exchanged is a better way to keep things cool, Just like running a larger radiator? I will have to look and see where I could fit this, I found a lot on Ebay for like 150, Morroso and ETD motors.
Old Jul 12, 2012 | 11:51 AM
Polar_g37s's Avatar
Polar_g37s
What is the benifit of a larger coolant tank, Just that more coolant to flow would keep it cooler, I know it sounds dumb, But more to flow through the exchanged is a better way to keep things cool, Just like running a larger radiator? I will have to look and see where I could fit this, I found a lot on Ebay for like 150, Morroso and ETD motors.
I think that a larger coolant tank would do nothing. An engine can only take a certain amount of coolant and having a larger tank would do nothing but have more coolant sitting doing nothing. Bigger rad is a whole different story that definitely helps with cooling.
Old Jul 12, 2012 | 12:42 PM
ANMVQ's Avatar
ANMVQ
Opps my fault man, I meant running a Super charger coolant tank with my upgreaded heat exchanger, Sorry if I confused some of us, :/
Old Jul 12, 2012 | 01:04 PM
Weiboy718's Avatar
Weiboy718
Know what's more efficient than swapping out to a bigger heat exchanger? It's adding a fan to your existing STILLEN heat exchanger to draw more air. Also you'll need to account that by adding more coolant you may also need to upgrade to a bigger pump. Just my $0.02 cent.
Old Jul 12, 2012 | 01:12 PM
ANMVQ's Avatar
ANMVQ
Was think about the fan idea, The pump should be fine, I have been poking around the SVT forums and those guys are staying with the stock pump. The tank I'm looking for is just a little bigger nothing to crazy.
Old Jul 16, 2012 | 11:07 AM
ANMVQ's Avatar
ANMVQ
ok so heat exchanger will be at the dealer tomorrow, and I just picked up the UPREV MAF's. I should have those of Friday, and will be making a APT for a return for those plus a pulley upgrade 10 PSI.
Old Jul 17, 2012 | 01:45 AM
timp's Avatar
timp
Sounds like someone wants more fun! Isn't HP contagious.
Old Jul 17, 2012 | 12:48 PM
ANMVQ's Avatar
ANMVQ
YUP and exspensive,,LOL
Old Jul 25, 2012 | 10:02 AM
ANMVQ's Avatar
ANMVQ
Ok so just ordered the last part yesterday,
So the run down is below hope to get close to 480-500 WHP. Wanna Thank Seymore and MR.Squezze for the help along the way,
34 Tooth Count Jackshaft Pulley
30 Tooth/35mm Supercharger Pulley
idler assembly from a 03-05 350z bracket
Gats belt Part number 560 8M GT20
Bosh EV14 Injectors 850CC
Frozen Boost Air To water Heat Exchanger 24"X7"X3.5
NGK Plugs( GTR) DILKAR8A8 X 6.
UPREV MAF's.
misc
29
May 24, 2023 03:57 PM
alxmlr789
Dec 1, 2015 03:55 AM
czirrfb
Sep 16, 2015 04:09 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
