Fumoto Valve question
Old Jan 23, 2012 | 03:36 PM
xceebeex's Avatar
xceebeex
I am thinking about going with a Fumoto Valve for my G37. We have it on our Acadia and I just changed the oil for the first time since installed it and I must admit, it is real nice to have.
Anyway, my question is if I go with the valve, would I use the washer that they provide or do I need to get one of the copper crush washers and install that with it instead?
Thanks!
Old Jan 23, 2012 | 05:03 PM
Weiboy718's Avatar
Weiboy718
As good as it sounds to have one I still wont get one especially being lowered. It only takes me a few seconds to remove the oem drain plug when changing oil.
Old Jan 23, 2012 | 07:44 PM
xceebeex's Avatar
xceebeex
With the plug on the side of the pan AND a plastic shield over the drain plug, the chances of the valve failing are so slim it isn't worth worrying about. If you get to the point where you damage the valve because you bottom out, you have MUCH more to worry about than a failing valve.
Bobo
Oct 1, 2015 10:52 PM
JG_G37
Sep 19, 2015 09:07 PM
si_driver
Sep 12, 2015 10:38 PM
johnadlertech
Sep 11, 2015 02:07 PM
