Help Supercharger on 2008 coupe auto tranny?
Old Apr 20, 2011 | 10:03 PM
dal1307's Avatar
dal1307
My 5AT is holding up just fine. I have not yet installed the valve body upgrade but the Uprev tune included a transmission re-program that greatly reduced the shift time and keeps the tranny from slipping during shifting. It shifts extremely quickly and hard now, especially in S or Manual mode. I do have the Tranny cooler.
Old Apr 20, 2011 | 10:50 PM
Dieseldoug22's Avatar
Dieseldoug22
Originally Posted by Fezzik
It is confirmed
VHR + FD Gear Ratio upgrades - 3.9 and 4.08 - Page 8 - Nissan 370Z Forum
This is of course on a 370z but its just about ecact to the G on this regards
Thanks Fezzik for the info. That sucks I was hoping I could do the swap and not lose the Cruise.
Old Apr 21, 2011 | 12:15 AM
whiddles's Avatar
whiddles
I have the Stillen SC on my 08 G37S auto. I have about 10k miles on the SC kit and not Valve body upgrades just tranny cooler. It runs great. Nice smooth shifts everytime
Old Apr 21, 2011 | 07:02 AM
mikelr's Avatar
mikelr
I guess if you get the Stillen kit you can leave your tranny alone... the GTM kit makes too much torque under the curve for the stock tanny to survive....
Old Apr 21, 2011 | 07:10 AM
Weiboy718's Avatar
Weiboy718
Seems like all the stillen fanboys are riding AT's LOL. Mike nailed it, that kit's TQ is way too weak to blow tranny's but good enough to blow engines haha.
Old Apr 21, 2011 | 04:46 PM
terrycs's Avatar
terrycs
Originally Posted by coolraz
What about the 7at? Can supercharger be used safely on it. I know for example You can't floor it in 7th or 6th gear bc it will slip. But what about if you shift manually and only go WoT in the low gears? Would it be ok then ??
If a shift kit is installed, you get faster, firmer shifts in DS mode instead of M mode (shift algorithms are different). So off the line, DS mode is better in terms of wear and tear on the AT.
No matter what you do, you can't go WOT off the line with FI unless you want your rear tires to disintegrate.
Old Apr 21, 2011 | 04:49 PM
terrycs's Avatar
terrycs
Originally Posted by shumby
OK here is the deal. 5th 6th and 7th will start to slip if you get stupid like me and floor it in those gears while at cruzing speed. Now that said I have taken my f'ed trans out and shipped it to SAM @ GTM. The replacement trans I have now is holding up fine I changed my driving habits and now down **** on the hiway when i want to have fun and make sure to shift onbly close to redline after 4th gear. Sam should have my trans rebuild and beefy sometime by the first of next month. Then I will but it to the test.
What are they gonna do to beef up your trans?
Old Apr 21, 2011 | 04:53 PM
terrycs's Avatar
terrycs
I've heard that there is a TCM re-program that will give quicker shifts in BOTH M and DS mode. Do you have any more info on this?
Old Apr 21, 2011 | 06:33 PM
dal1307's Avatar
dal1307
Uprev provides re-programming of the TCM. My tuner, Nick backed off a little from the recommended parameters as the shifting was really severe. These parameters were recommended by Uprev for FI applications and are set to allow minimal slipping during shifting. Nick thought it was too severe when he did the drivability testing and backed off a little Een after the adjustments he made it shifts very fast and hard now in DS and M. It will really snap your neck from 1-2 and 2-3 and is worlds different from the factory programming. In D, it shifts much more sedately and is much closer to the factory feel. I am assuming that there are different programs for D, DS and M or possibly for D and DS & M but I am not positive. I will talk to Nick when I get a chance and find out more information.
Old Apr 21, 2011 | 06:53 PM
dal1307's Avatar
dal1307
Not going to take the bait boys LOL! I am very happy with my setup and have had no problems to date. I am not even running 8 PSI (7.2 psi with a 9 psi pulley due to the altitude) and my AFR curve is very conservative (i.e. safe). I am sure I could get a bit more HP and TQ with a pulley swap and minor re-tuning (about 20 additional HP and 12 ft-lbs TQ at 8 psi by my calculations based on the gains from the baseline) but I am concentrating on brakes and suspension now. My car makes me happy and that is all I care about.
Old Apr 21, 2011 | 07:13 PM
GraphiteG37S's Avatar
GraphiteG37S
^ It's not the Stillen S/C Wei, you know it's their tunes that destroy motors. Dal was tuned a Mac I believe. His car is a prime example that the product may not be fault.. But the tuning may be Stillens downfall. I'm sure Dal will continue to keep us up to date with Stillen S/C experience. RCZ on the 370 forums is reportly not having issues with his Stillen S/C, but he's not running their canned tunes either.
Old Apr 21, 2011 | 07:31 PM
coolraz's Avatar
coolraz
Is the uprev TCM program available for NA? Or rather, does it improve the shifting if you don't have FI? I assume this is in the custom tune because the only stuff i got in my uprev Osiris tune is AFR...
Also, is the shift kit (i assume you mean the GTM/transgo ) worthwhile on an NA car (assuming it's got intake, exhaust, HFCs and catback) or there too little hp increase to make a difference?
Old Apr 21, 2011 | 08:51 PM
dal1307's Avatar
dal1307
It had nothing to do with the NA versus FI, it was the custom tune. It would definitely improve the shifting for a Naturally Aspirated car. I am sure that the shift kit is worth the price also. I plan to have one installed eventually. It is not really that expensive although I do not know what the installation cost would be. You can order it from GTM or possibly even direct from TransGo. There is a thread for a TT installation on a 2008 5AT that included the TransGo kit. I can't remember the name of the member but he actually did the installation himself in the shop where his install was being done.
Old Apr 21, 2011 | 09:53 PM
  #29
Weiboy718's Avatar
Weiboy718
i know man! just trying to spice things up a bit hahaha.
Old Apr 21, 2011 | 10:50 PM
  #30
dal1307's Avatar
dal1307
I thought FO SHO that when Graphite threw out RCZ the sparks would fly LOL!
When is all that painting and other stuff gonna be down Wei? I need to subscribe for updates as I am anxious to see what all UR doing.
