Problem on starting
Old Jan 6, 2011 | 07:21 PM
onceagain's Avatar
onceagain
Problem on starting
I have an 08 G37S and every now and then when I go to start, either it dosen't start on the first time,,, Hot or Cold,,, also sometime's it feels like I'm going to stall..Whats up with that,,,
Old Jan 6, 2011 | 07:55 PM
Felix_the_Cat's Avatar
Felix_the_Cat
Dealership time! I wouldn't mess with it let the dealer handle it if still under warranty
Old Jan 6, 2011 | 08:20 PM
Staples's Avatar
Staples
Could be the battery... They are prone to suck. I had to just replace mine last week. It could also be the alternator but that isn't very likely. If you have a lot of mileage on the car it could also be the spark plugs beginning to foul out.
Old Jan 6, 2011 | 08:35 PM
goarmyg37's Avatar
goarmyg37
Sparks plugs. Does anyone really have enough miles on an '08 for this to be issue? I have been under the impression we should be able to get 100K(+) out of them if there are not a lot of mods. Am I off base thinking this (would be par for the course for me).
Old Jan 6, 2011 | 09:14 PM
Staples's Avatar
Staples
That would be the general consensus, but with vehicles there always can be issues. I have less then 32k on my car and my battery died for good and wouldn't hold a charge. Wouldn't you think you would get 60k+ miles out of it before actually having to replace it?
That's what warranties are for... to fix issues when certain things break / need to be replaced at low mileage.
Old Jan 6, 2011 | 09:18 PM
3BEP6's Avatar
3BEP6
When you say not starting, is it cranking and no fire up for a while or else? Also when it almost dies in idle describe it more..
Old Jan 6, 2011 | 10:04 PM
3BEP6's Avatar
3BEP6
Old Jan 6, 2011 | 11:05 PM
onceagain's Avatar
onceagain
Ok just over 22,000 miles still have plenty of warranty, cranks, no start, stop and try again and it starts, or it will start and feel like its going to stall... I'll just take it in ,, thanks
Old Jan 6, 2011 | 11:21 PM
Fezzik's Avatar
Fezzik
Junk in the tank maybe? hard to tell, but defintely a dealer time issue
Old Jan 7, 2011 | 09:43 AM
ohsogood's Avatar
ohsogood
Does it sound like this?
YouTube - Start up.mpg
https://www.myg37.com/forums/g37-cou...-cleaning.html
I had the same problem and they still have my car at the dealership. They replaced the battery, valve, and now fuel pump but still no luck.
Old Jan 7, 2011 | 08:56 PM
onceagain's Avatar
onceagain
Its going to the dealer tuesday ,, I will post a follow up
Old Jan 7, 2011 | 08:59 PM
g37jatt's Avatar
g37jatt
I have the exact same issue. Mine is also going to the dealer on Tuesday.
Old Jan 7, 2011 | 10:58 PM
ohsogood's Avatar
ohsogood
Good luck.. Got s call from the dealer stating mine was all fixed up. I'll find out what the problem was tomorrow.
Old Jan 13, 2011 | 01:16 AM
chad2074's Avatar
chad2074
I'm really curious what your dealer said...I had the exact same problem where the engine fires up just fine (no cranking), but dies almost instantly after. Dealer said my battery was weak, but I'm still having the problem after I got a new battery. I've got an 08 with 55k miles on it.
Old Jan 13, 2011 | 12:13 PM
onceagain's Avatar
onceagain
Ok, picked up the car today,, they said there was a recall on the battery and a updated vent solenoid part # 23710-jk788 and they did a engine reprogram ,, will see
