Engine Shield - Underneath Engine
We need to get a group buy together - here are pictures of what the shrouds look like. Decide on whether
1. Flat black PC or brushed aluminum finish
2. Vents or no vents
3. Hardware kit or just reuse factory
Brushed Aluminum version for G37
Brush Aluminum version for the G37X
Brushed Aluminum version for the G37 with vent - AWD version would be similar. The oil door has lines that match up with the rest of the shroud to make it look complete.
Same things but in Flat Black Powdercoated finish
Somehow I totally missed this thread. I sent you my under shield for test fitting/measurements. I like the 3 piece. Will it have additional cooling vents like the other ones you have for the G35?
oo exactly what i was looking for...
but i removed the plastic underliner because i was scraping it too much. With this im certainly sure it will scrape.
How much lower does this sit than the original piece? 1"?
Price point is set to be around $200 + shipping HOWEVER
IF WE GET A GROUP BUY we can do an introductory pricing and drive that down.
This won't necessarily sit much lower than the original piece - you won't really scrape too often with this. However, it will still allow for you to utilize a 1" oil pan spacer if you'd like.
My splash shield is pretty messed up. I did find an image from a store though that might help.
Ok, I'll need to check on it, but it looks like the G37X is very similar to the G35X - but it probably has the same dimensional changes that took places between the G35 -> G37 (a little wider, hole locations, etc).
I forgot to mention that I have a g35X 2nd gen sedan (2007). I assume it has the same splash shield as the g37 sedans.
I think you're right. They all use an HR motor, so all 2007-2010 AWD version should be the same, and the 2007/2008-2010 3.5 and 3.7 HR motors are probably all the same.
What I find interesting is that the 370Z still has the same design as the G35.
I just need to meet up with my test vehicle one more time.
