Intakes void tranny?
Mind emphasizing on the "transmission issue" that you had?
Not only do they have to prove it, but they have to prove it to the point it will hold up in court. It's called the Magnuson-Moss Warranty Act and 99% of the time if you call them out on a false claim of blaming some other part, they will cave. It is not worth them going to court when it's cheaper for them to replace a part.
I had my synchronizer go out. causing my 5th gear to grind everytime. every other gear was fine outside 5th. my dealership here in missouri has been very good to me in handling issues with my G.
oh wow. Thats pretty goodo ver there in missouri.
My 2nd gear will SOMETIMES grind if i dont push it hard enough into gear. and my 3rd gear seems to be not consistent going into that gear
While we're at the subject of trannys,
I've been having issues with mine. Occasionally, when I'm taking off from a complete stop (i.e. stoplight), The car would seem to struggle to catch gear and take off and would "chug" along for a second or two. Does anyone here have the same problem?
whenever you normal shift and you grind gears, thats a way of telling your synchros are gone
SON415
Sep 28, 2015 05:49 AM
