D or DS
Old Apr 21, 2010 | 03:48 PM
ged1067's Avatar
ged1067
Originally Posted by Marc Collins
If you really want to not waste gas, then use Snow Mode. It replicates a "normal" car auto transmission shifting pattern and throttle response.
D is equivalent to a sporty mode in most cars.
DS is aggressive--too much so for any kind of normal driving as mentioned above.
I agree that either D (with or without Snow Mode) or manual is the way to go. DS is a bit silly and can't really anticipate the conditions you are driving in (hills, corners, traffic, etc.) so therefore cannot be in the right gear at the right time.
Thanks to all the responses; different strokes for different folks, but the above seems right for me.
GED
Old Apr 21, 2010 | 04:22 PM
Alex57r's Avatar
Alex57r
D = rpms too low. DS = rpms too high. Choose your poison. I use DS when taking turns and want to be "in gear" rather than floating around in 7th. If you want to canyon carve, manual mode is the way to go. Regular driving 99% of the time I think D is just fine.
Old Apr 22, 2010 | 07:56 AM
KLB's Avatar
KLB
Originally Posted by uwnav
snow mode is on the AWD cars. Reduces throttle response, so that you don't spin out as easily.
I'm confused about the better mileage argument, doesn't it also lock you into 4WD? (instead of 80%-20%), how would that be better for gas?
No, it does not lock the car into AWD.
Old Apr 22, 2010 | 09:44 AM
jwoods986's Avatar
jwoods986
I try to keep it in D but it upshifts so early/quickly in each gear that I'm constantly "caught out" of gear when trying to move quickly. Like changing lanes in traffic or merging onto a highway. It gets so frustrating, so I end up doing M mode a lot of the time.
DS is pretty good for spirited driving, but keeps the rpms too high for daily driving and sometimes doesn't downshift when approaching a turn. So once again, I'll usually end up going to manual mode. I don't have the S package, so I don't have the option of having it in D, then automatically going into M via the paddles. I have to go to DS first.
Old Apr 22, 2010 | 11:01 AM
ONEighty's Avatar
ONEighty
Uhh... M...T.
Old Apr 22, 2010 | 11:09 AM
hadokenuh's Avatar
hadokenuh
My advice: Install the paddle shifts. I did it myself and it works great. I don't have the S package either.
Old Apr 22, 2010 | 12:21 PM
finagle69's Avatar
finagle69
DS will converge with D over time if you drive non-spirited. This is due to the "learning" nature of the ECU.
My advice is if you're just driving normally through traffic, use D. If you're wanting to drive spirited, kick it into DS, but when your satisfied, switch back to D. This way, the ECU doesn't learn based on you taking turns at 15MPH after you're done.
I never use DS anymore, either D or MM.
Old Apr 22, 2010 | 12:27 PM
FourT2's Avatar
FourT2
Can you provide some more info, like the cost of the parts, how-to, etc?
Old Apr 22, 2010 | 12:35 PM
hadokenuh's Avatar
hadokenuh
Search the forum. There are a bunch of threads on this, with at least 2 ways to install. Cost is around $250.
Old Apr 22, 2010 | 02:46 PM
freesurfer's Avatar
freesurfer
This is fascinating tell me more about this learning ECU.
Wouldn't the D/DS also converge over time if I was driving "spirited"?
I don't understand not using DS anymore, it just retards shifting and allows me to use the upper band of the rpm more. Maybe because you're driving non-spirited now? Not doubting you, just want to learn more.
Old Apr 22, 2010 | 02:54 PM
G37Sam's Avatar
G37Sam
The way I see it, the only benefit from DS is the perfect shifting (especially in first), otherwise it's just a waste, get used to driving in M mode, I think it's the best since YOU get to control at what rpm to shift.. Only wish the paddles were a bit more responsive
Old Apr 22, 2010 | 03:17 PM
Alex57r's Avatar
Alex57r
THis whole learnign this is a bunch of BS. Most cars today "learn" or adjust to your driving. My car drives the same whether I baby it for weeks or beat on it constantly. I see no perceptable difference. Its people brains that are "learning".
Old Apr 22, 2010 | 03:21 PM
finagle69's Avatar
finagle69
While that may be your experience, I drove with DS only for about 6 months. during that time, I noticed the car being less willing to downshift during harder braking as well as it being more prone to upshifting at a lower RPM. After doing an ECU reset, it was a noticeable difference back to how it "used" to operate.
Obviously, YMMV.
Old Apr 22, 2010 | 06:02 PM
  #29
cdso's Avatar
cdso
The only time I use DS is when I'm switching over to M mode. Other than that, it's doesn't really serve a purpose for me.
Old Apr 22, 2010 | 08:43 PM
  #30
15951's Avatar
15951
Perfect shifting would be a pretty solid benefit, seeing as how the transmission exists to shift gears. How is that a waste?!?
