FI Decision Thread
Old Mar 25, 2010 | 02:15 PM
  #136
philter25's Avatar
philter25
Originally Posted by WhosUrBuddiee
I actually want to talk to Stillen about using ethylene glycol/water solution instead. Very high effiency and less chance of being overwhelmed.
(Posted wrong solution before)
Heat exchangers for many industrial applications use a 50/50 water/ethylene glycol (WEG) solution for cooling. Not only does it lower the freezing point, but it also raises the boiling point so the operability range of the solution is broader vs. just water.
However, the heat capacity of WEG solutions are LESS than that of water. So to get the same cooling capacity as pure water, the volume of WEG circulated must be INCREASED.
The main benefit or using WEG is the increased temperature range of cooling.....
I would guess that some amount of WEG is probably added to the water to prevent from freezing. (Ive only owned a car with an air to air IC so Im not 100% familiar with air to water or the amount of WEG added) Otherwise, whats to prevent the water from freezing if you park your car outside overnight in the wintertime. The last thing you want is water freezing in lines in your car. But the more WEG you add, the less cooling capacity the fluid has.
Old Mar 25, 2010 | 02:23 PM
  #137
whiddles's Avatar
whiddles
what kit has everyone decided on? I'm just looking to see who is going with which kit?
we should start a poll.
Old Mar 25, 2010 | 02:24 PM
  #138
philter25's Avatar
philter25
Originally Posted by Mike
Air-to-water IC (usually incorrectly referred to as a Aftercooler) are more efficient at pulling out heat, but are more prone to heat soak, since most kits are not designed for long pulls and/or long sessions of WOT. A heat exchanger has to be used to keep the water temp down. For short sprints, this is awesome, as you can ice down the AC to cool your charge temperature even more.
Vortech kits often use a air-to-water IC on other cars... but most people running much more than the kit's stock power usually swap out to a air-to-air IC. See their Mustang or S2000 kits for example.
The design remains yet to be proven... only time will tell.
Agreed......(although I think I disagree on the terminology. Anything thats placed after the compressor/turbo/supercharger which cools the charge before it goes into the engine is technically an aftercooler. The intercooler name came decades ago when aircraft engines had multiple stages of charging, and in-line coolers were placed between the stages, hence the prefix "inter"........... but people tend to use the terminology interchangeably)
Im very interested in getting a more detailed schematic of their manifold with the IC built into it. Id be curious to know the surface area of the IC and if the volume of water circulated can be increased for better cooling.... although Im sure Stillen looked at this when sizing the pump to go with their system.
Also, wouldnt the location of the air to water IC also suffer from heat soak from the engine being that its essentially a top mounted intercooler on top of the engine?
Old Mar 25, 2010 | 02:35 PM
  #139
Mike's Avatar
Mike
Originally Posted by philter25
Agreed.
To a degree yes, but it shouldn't (theoretically in my mind) be that much. The intake manifold from the factory already gets pretty hot, and it doesn't affect performance much. Air temp of the intake charge is already pretty warm. Of course if the water inside the Aftercooler gets heated by the engine, that's not good. It all depends on the location of the aftercooler in the manifold, and how much heat is conducted to it. I really hope Stillen follows through on this with a spectacular design.
Innovation is always good, and this would pave the way for a spectacular comeback for Stillen.
Old Mar 25, 2010 | 02:38 PM
  #140
WhosUrBuddiee's Avatar
WhosUrBuddiee
Agreed.
The lines maybe, but Im sure they will be insulated. The IC itself will not be subject to heat soak since it will be located inside the manifold. The air between the manifold and IC will provide a natural insulation effect.
Old Mar 25, 2010 | 02:39 PM
  #141
Mike's Avatar
Mike
Here is a small one.
Cools it down to -10 degrees celicus.
1360 BTU/hr steady state.
Yes it is not nearly powerful enough to keep it chilled at that temp, but it could help keep the temp down.
I'm guessing you want to "refrigerate" the water? Wouldn't that expel more heat into the engine bay? (I guess relocating the battery and putting it where the battery was would semi-eliminate that problem... )
Old Mar 25, 2010 | 02:40 PM
  #142
Mike's Avatar
Mike
But at some point, there will be potential for conducting heat between the manifold and plenum...
With sufficient flow, I doubt heat radiated from the engine would be enough to significantly change the temperature of the water flowing in the lines. It's similar to how the tubes of a CAI aren't hot after a hard drive... the flow is so much that it just makes the radiated heat in the engine bay moot..
  #143
WhosUrBuddiee
Most chillers I have looked at include a high volume pump. (or you select on of your own.)
Old Mar 25, 2010 | 02:42 PM
  #144
WhosUrBuddiee
Actually I was thinking of relocating the battery and the chiller into the trunk and putting the resivor and pump in the area of the battery.
Old Mar 25, 2010 | 02:45 PM
  #145
Mike's Avatar
Mike
You gonna be the first one with a vented trunk?
But seriously, that would have the same/similar effect as icing down the aftercooler and/or putting ice in the resovoir.
What would be the weight penalty of doing all this? The kit, wires for relocating the battery, chiller, lines for the chiller, etc. Relocating all this to the back would help a bit with weight balance, to a degree.
Old Mar 25, 2010 | 02:48 PM
  #146
philter25's Avatar
philter25
^ in addition to relocating the water lines to the trunk, additional lines and bends are going to cause additional losses, which might cause a reduction in flow through the air to water intercooler.... and any reduction in flow reduces the amount of heat that the water can take out of the intake charge. Depending on how much additional cooling you can get by relocating it to the trunk, it might not be worth your while. And if you can only realistically get a few additional degrees of cooling, thats a lot of work and additional relocation just to get that.
Hence why I'd like to see a more detailed schematic or a flow chart of their custom designed manifold.
Ehhh.... I dont know if I agree with that. But I guess time will tell!
Old Mar 25, 2010 | 02:50 PM
  #147
WhosUrBuddiee
Again all of this is just me thinking out loud. Also that small chiller I posted only weighs 12 lbs and has a small btu capacity, I really dont need to worry about airflow to it.
Old Mar 25, 2010 | 02:51 PM
  #148
Mike's Avatar
Mike
The air inside would (minimally) cool the manifold/engine....
Now that I think about it, I think the little air conditioner I have for a single room is rated at like 9000 BTU... and I think the charge would require a rather large amount of cooling to be noticable...
Any physics experts want to chime in with some calculations?
Old Mar 25, 2010 | 02:56 PM
  #149
WhosUrBuddiee
Also Stillen did ALOT of testing, Im sure they have taken into acount all of this.
Repeated high speed runs in excess of 140mph
Temperature monitoring (just a few of the many data points we collected during our testing)
IAT pre and post intercooler under hard driving conditions
Engine Oil under hard driving conditions
Intercooler coolant under hard driving conditions
Transmission performance under hard driving conditions
Effects of airflow to new coolers without impeding flow to radiator under hard driving conditions
Transmission stability – starts, cornering, up and down shifts under loads
General drivability - part-throttle, full-throttle, stops, starts, different loaded conditions
Old Mar 25, 2010 | 03:00 PM
  #150
Mike's Avatar
Mike
TBH, repeated low-speed WOT runs are much harder to keep cool than repeated high-speed WOT runs, due to decreased airflow through the engine bay.
E.G. guys who hit limp mode at Streets of Willow (technical track) vs guys who can do WOT runs on the freeway for extended periods of time (5+ minutes at WOT 95% of the time) without hitting limp mode.
