Problems with transmission?
I have cought some nice delay, i think this is because of the down shift rev match.
Mine is a 5 at, i did have a loaner with 7at.g37x.
so comparing both,the 7at is worse,seemed like it was always looking for the gear super annoying in stop and go.
I also think it has to do with the fact the throttle never fully opens & the car kinda chokes out.
This happens to me any time I try to pull out and pass on the interstate and floor the car. Huge hesitation then the car downshift to too low of a gear (i.e. almost redline) and then tries to upshift only to hang at the high revs with no actual engagement of any higher gear until I let off the gas pedal and then it upshifts. I've said it before...can be hazardous.
I spoke with the Master Tech at my local Infiniti dealer about this in the past and he suggested that I file an offical complaint with Infiniti so that they would open an investigation into this issue. I would suggest that everyone here do the same. Its the only way we'd be able to get them to look into this.
Thx
I had started this post sometime back.....
https://www.myg37.com/forums/g37-cou...g-for-1st.html
Thx
just got the answer, infiniti has made some change to their trans fliud.
the TSB calls for some new type of fluid, if that does not fix it.
Guess we will all be getting a new trans.(reminds me of the oil consumtion problem)
Is there a new TSB which calls for the new fluid? What is fluid supposed to do about the kind of problems we've been experiencing?
power train automatic transmission
nhtsa#10024688
special transmission fluid
itb08-022
My dealer states it is a new fliud, all the complaints about mis shifting. delay when accelerating.
I will give the exact info from the repair order once i get the car back.
And FYI when the trans is hunting for a gear, that is a saftey issue.
nhtsa#10024688
itb08-022
Has anyone gotten this issue resolved yet? I had the issue resurface again this afternoon. pulled out to pass a corolla from a stop sign infront of a big rig and had the fear of god put into me. Engine rev'd all the way up to redline and nothing happened. Nothing at all. I looked down at the dash and for some reason it displayed 1st gear. I know for a fact that I was in sport mode (110%) sure.
Its the same routine that I do every single time because its a stop sign that I run (not proud but I do it). The person infront of me stopped at the sign, as did I. I put the car in sport mode - its a merge onto the freeway so I knew that i was going to pull around her - and as she pulled out I did to. I pull out and gave about 80% throttle, car started to pull a little then the rev counter goes all the way up.
Even if I somehow had accidentally engaged manual mode the fuel cut off didn't engage (rev's were still increasing). I then proceded to put the car back into auto mode and the tranny still did not engage and when it finally did it was VERY rough with a clunk and it was a very jerky pickup after it engaged (lurching of sorts). All of this caused the slip lights to flick on and off as if fighting for traction. This is the fifth time that this has happened and the third time where it almost caused and accident. I also have opened two cases with Infiniti consumer affairs but they've said there's little that they can do. If anyone else here is still having this issue please contact consumer affairs and open a case regarding this issue.
Thx
Luckily I had a witness on one occasion because whenever I had mentioned it in the past the tech's looked at me like I had two heads.
Thx
i went to the dealer and told them about the problem.. mechanic came with me and i showed him exactly what i was experiencing and he told me it was normal -_- it seems like a lot of people have similar problems and the only real solution is to drive in manual mode when getting heavy on the gas from a stop. im pretty sure you wont get damage because of the fuel shutoff but the problem is annoying and infiniti should have the decency to attempt to fix the problem regardless of what it is. pisses me off to drop 40k on a car and then have problems like this..
It seems to me when they don't know how to fix or simply don't want to fix something, they just say "it's normal". I've actually floored mine from a stop a couple of time in DS and never seen anything like that. How did he explain it was normal? I am curious.
Good luck though!
Good luck though!
After reading this, I took my 3 - month old G37xS on an open spot and clicked off two 0-60 runs - one in "D" and the other in "DS". No issue on either one, clicked cleanly between gears shifting just before redline.
I do find the shift programming and shift behavior annoying in normal driving; there are some random and unpredictable reaction to small throttle changes. Not nearly as refined as the 5AT in my old TL. I would class it as a minor annoyance. I have not experineced anything remotely like what you guys are describing.
Greg
Greg
Well I took it in today and we we're somewhat able to replicate the issue. The tech called it a 'sticky transmission'. Long story short they will be replacing the tranny. Strange though it is I really don't think think that the tranny is bad, I get the impression that the software controlling it is faulty and not selecting the correct gears. More of a confusion thing, where it upshifts then tries to downshift and gets caught out there in space.
