VQ37VHR intake manifold???
Old Oct 4, 2009 | 09:18 PM
AvosG37's Avatar
AvosG37
is any1 makin new TB for more power???
Old Oct 4, 2009 | 09:24 PM
Ivoidwarranties's Avatar
Ivoidwarranties
Yeah, you're right on that one. I might try that later. This shouldn't be that hard of a question.
The throttle bodies are not a restriction.
Old Oct 4, 2009 | 09:26 PM
G37Sam's Avatar
G37Sam
I believe Impul made after market throttle bodies check out their website
Old Oct 5, 2009 | 11:39 AM
terrycs's Avatar
terrycs
Originally Posted by Ivoidwarranties
I just want to know how the two sides equalize. I want to find a dissected view of the upper half.
OK .. I think we are both curious to know what is going on in what you call the "upper manifold". I bet Modme would know since he had to drill his out in two places for his TT project:
https://www.myg37.com/forums/engine-...2-install.html
He would have to clear the shavings out somehow.
I have a feeling it is just one big chamber though because folks with the DE motors wanted to increase the internal volume of theirs by adding spacers.
Old Oct 5, 2009 | 12:50 PM
RISKY GUY's Avatar
RISKY GUY
larger throttle bodies are the way to go.
from when i had on my stang, it was a huge diff in power.The 5.0 only has 225hp stock so, there was alot to gain by switching around a few parts(no one did tuning)
I had (high flowgt40 cylinder heads),(high flow exhaust)(stock cats gutted out)(Pulleys (65mm throttle body)& a (piggyback chip,plugged into the stock ecu.)
car was a monster,i would destroy stick vettes(stock) & even romped a grand national*(that was the fastest car in production)
With more airflow *(vvel loves more airflow) & more fuel*(dont think the extra fuel helps without adjusting the timing.)
just my .02 cents.
Old Oct 5, 2009 | 02:38 PM
Modme's Avatar
Modme
I did have a peak inside. It was very dark in there and hard to see but from what I remember, it is basically the same as the VQ35de plenum. It is one big chamber with 6 intake runners, so air pressure should equilibrate evently. Not 100% sure tho.
Old Oct 5, 2009 | 05:41 PM
Ivoidwarranties
I would be very very surprised if it is one big air chamber. Usually, these are very complicated with air being ducted all around inside before it gets too the runners. I'm not saying it's not a big chamber, but I am saying I would be real surprised if that's all it is.
This would also be very important for people considering running a wet nitrous system. This is the area where "puddling" becomes an issue.
Old Dec 30, 2009 | 09:29 PM
Ivoidwarranties
Someone should make a spacer/nitrous plate to sit atop this.
xxg00w0
Intake and Exhaust
42
Mar 18, 2021 07:44 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
hamkha1ebay
Sep 28, 2015 02:38 PM
SON415
Sep 28, 2015 05:49 AM
