Help CEL and codes .. help out
Old May 4, 2009 | 11:55 PM
VONYC's Avatar
VONYC
Alright so i was driving all day .. i didnt drive like an A$$ at all ...
Last time i get in my car and the CEL turns on .. FML ..
lol its not my HFC alreast i dont think it is ... i had the stage 2+ map on my car.. i dont have headers but my AFR were like 14 high 13...
i kept it at that and my car was running normal ... I just changed to the stock style map right now and no CEL ... cuz it reset the ECU ..
Well i got on the cobb and looked up the codes to read and it gave me
BCM
C1708
C1709
C1710
C1711
IF anyone know what these codes mean and post it for me i would really appreciate it ..
thanks !
Old May 5, 2009 | 09:08 AM
VONYC's Avatar
VONYC
anyone ?
Old May 5, 2009 | 09:19 AM
tristan1334's Avatar
tristan1334
Body Control Module controls most electronic function except engine. Mine lit up when I lower my tire pressure(track/drag) and when that idiot ran my car on the dyno with VDC on. My friend broke one of the tire sensors and it threw a BCM code. But if you cleared it using the AP then it should not come back. Hope that helps.
Old May 5, 2009 | 09:23 AM
VONYC's Avatar
VONYC
That helps a lot actually ... I am not running with my tpms sensors that's why it came out right ?
Thanks
Old May 5, 2009 | 09:32 AM
tristan1334
Yup, that's the problem. Don't worry there's no performance loss on that.
Old May 5, 2009 | 09:35 AM
VONYC's Avatar
VONYC
Alright lol I thought it was the stage 2+ map
making my car run lean or something ...
Do you know if it's going to keep popping up ??
Old May 5, 2009 | 09:45 AM
tristan1334
Yes it will till you put the tpms back on. I wouldn't use stage2+ unless you have headers.
Old May 5, 2009 | 09:47 AM
VONYC's Avatar
VONYC
what map would u use ? the stock style map ?
Old May 5, 2009 | 09:56 AM
NJlakeshoreG's Avatar
NJlakeshoreG
stock style map, is the factory tune...no performance enhancements...NONE at all....believe me, if not ask cobb............
Old May 5, 2009 | 02:48 PM
VONYC's Avatar
VONYC
so what map should i use lol ?
Old May 5, 2009 | 02:54 PM
C@ciQ's Avatar
C@ciQ
Bro I told u Stage 2 because it was richer than 2+.
Old May 5, 2009 | 02:57 PM
C@ciQ's Avatar
C@ciQ
If it is the TPMS warning light should pop not the CEL. Anyways u can clear em out.
Old May 5, 2009 | 03:27 PM
VONYC's Avatar
VONYC
I did clear them and they both come out after an hour ... I called infiniti they said the CEL will NOT come out if u don't have sensors .. So it's something else ... I've had my hfc on for about a month n it never gave me s light till now ...
Old May 5, 2009 | 04:01 PM
VONYC's Avatar
VONYC
nvm .. i did some more looking around with the cobb and looked at it with the car on and off and i found out what the CEL is on for ...
P0430
TW catalytic system Bwk 2
something like that ..
so i guess it is my HFC .. DANM !
so how do i get that fixed lol ?
Old May 5, 2009 | 04:04 PM
aliiin's Avatar
aliiin
BMW Defector
dang that sucks.... how long did you have your HFC's for before it came on? how many miles were put on it?
