Help Whining like a SuperCharger!!!
Old Dec 24, 2008 | 05:07 PM
NJlakeshoreG's Avatar
NJlakeshoreG
Originally Posted by G37Sam
i don't understand why you're compaining lol
gears in the trans no good
Old Dec 28, 2008 | 02:29 AM
EVO-to-G's Avatar
EVO-to-G
alright i just started hearing this tonight...with windows up i can hear it and as i slowly accelerate i hear it whining more until the exhaust tone kinda beats it out.
i only have about 2500miles on it wtf is up with this?!?
is there any other signs i should look for to see if this really is a tranny problem?
Old Dec 28, 2008 | 04:28 AM
NJlakeshoreG
throwout bearring knocking...sounds like metal is floating around ur tranny...really crappy noise..
Old Dec 28, 2008 | 03:00 PM
da mayor's Avatar
da mayor
you still hear it after the upgrade?
Old Dec 28, 2008 | 03:48 PM
SlateBlue G's Avatar
SlateBlue G
Big Pei have u gone to the dealer yet?Im prolly gunna bring my car in after the new year. let me know pei if u get it fixed
Old Dec 28, 2008 | 07:17 PM
EVO-to-G's Avatar
EVO-to-G
im not really sure what the sound is about the throwout beaing.
but if the clutch is not pressed in i hear some sort of whining or something. when i press the clutch in it goes away...does anyone else hear this...is this a sign of a bad tranny?
Old Dec 29, 2008 | 01:54 AM
NJlakeshoreG
keny so far its as oas gold...if i ride my clutch hard going up my driveway backwards, since its steep as soon as i stop i hear the throwout bearring moving but then stops...
Old Dec 29, 2008 | 06:41 AM
sbmwg37s's Avatar
sbmwg37s
My car is always loud..somehow.. a lot of noise from enigne, clutch and muffler?
I thoguth everything were normal? lol...
Old Dec 29, 2008 | 07:57 AM
NJlakeshoreG
lolol....def take it to the dealer and complain....they will fix the problems....
Old Dec 29, 2008 | 11:27 AM
terrycs's Avatar
terrycs
Low power sterring fluid could also cause the pump to whine. The whining will also vary with RPM. May as well check all the other fluid levels while you are at it.
Old Jan 4, 2009 | 02:54 PM
EVO-to-G's Avatar
EVO-to-G
alright so i came to the conclusion that i will be calling infiniti to get this checked out.
this is what i hear...when the clutch is NOT pressed in, i hear a whining noise when i rev it...if the clutch is pressed in and i rev it, it goes away.
My question is do you guys think infiniti will give me a hard time since i have Stillen Gen. 3's in and Berk HFC's. I will obviously set my car back to stock via my cobb ap also.
Old Jan 4, 2009 | 02:55 PM
aliiin's Avatar
aliiin
BMW Defector
hfcs.. maybe... um if you messed with the ECU with the cobb ap then yes they will give you a really hard time... messing with stock ecu will definitely void your warranty... no doubt
Old Jan 4, 2009 | 02:59 PM
EVO-to-G's Avatar
EVO-to-G
^^^but with the ap it saves your stock map...so if i change it back to stock wouldn't i be fine then?
Old Jan 4, 2009 | 08:49 PM
  #29
EVO-to-G's Avatar
EVO-to-G
bump...I'm probably gonna call infiniti tomorrow or tuesday...anyone else know if I'll have a problem with what I have in the car?
Old Jan 5, 2009 | 08:28 PM
  #30
ucla bruin's Avatar
ucla bruin
For some reason I think so cal dealers will just say "that's normal, nothing's wrong" :/
__________________
