Trackday Datalog - Hello Limpmode
Old Oct 14, 2008 | 01:35 PM
  #31
Thrillhouse's Avatar
Thrillhouse
I'm also just using dealership oil at the moment. My receipt on my first change said "synthetic blend". I wish someone could find a way to read the oil temp sensor. I can't find any software for my interface that knows about it.
Old Oct 14, 2008 | 07:14 PM
  #32
bboysteele's Avatar
bboysteele
There is a TSB out now for dealerships to use estor oil (I think that is what it is called) and not use regular oil. I wonder if this matters.
Old Oct 14, 2008 | 08:08 PM
  #33
RedG37SNC's Avatar
RedG37SNC
I filled with mobil 1 last time, $60 vs $100 for ester, thought it was a dealer gimic. After reading about it though I'm going Poly Ol Ester from here on out. I wonder what brand they're using, Redline is only $10/qt.
History of Engine oil and this article below are interesting reads.
SYNTHETICS IN THE USA. @1996 rewrite ~2000©
In the USA there are a few different types of synthetic base stocks used in engine oils. We will just touch on two in this technical / sales paper.
The word Synthetic is confusing; it describes a process, not a material. For example, White sand is synthesized into glass, but glass is never called "synthetic sand". Most people think that all synthetic oils are made of the same base, This is wrong! For most of the USA, there are mainly two types of synthetic oils (or as we like to say, synthetics are designer oils).
The most common is a PAO, short for poly-alpha-olefine, or easier to understand, it is synthesized petroleum oil. It is refined in a special process, or in simple words "synthesized". It still starts out by being pumped out of the ground. PAO’s are better than regular petroleum oil for handling heat, oxidation, low temperature startups and higher film strength. Drawback: PAO and petroleum are dynamic types of oil, you have to build up oil pressure and have rotation before a film is produced. Better said, you have to hydroplane the engine parts like you hydroplane a car in the rain, to create a film (or in the case of water-skiing, you have to build speed for the skier to get up and plane on the water). PAO’s are not very expensive because they are made from crude oil and produced in large quantities. You can usually tell when PAO’s are the main ingredient used as the cost of the 100% synthetic oil is less than $7.00 per quart.
The other main type of synthetics are synthetic esters, (diester, polyolesters, polyesters and complex esters). Motul® uses esters in its products. Esters are mostly made of vegetables, minerals, and animal fatty acids. Motul’s® esters contain a lot of coconut derivatives. Esters are much more expensive because the ingredients all have to be collected from natural resources and synthesized (a very expensive process) in smaller quantities. Esters have all the advantages of a PAO but more of them. Esters can handle heat better than PAO’s and when burned, esters leave far less coking deposits. Esters are static types of oils and are attracted to metal parts with an electro-chemical bond. This means no more metal to metal start ups. This also means that a film is there before the oil pressure light goes out preventing premature wear of high-stressed parts like cam lobes. The film created is up to 5 times stronger then petroleum oil.
The number one reason to run an ester synthetic oil is bond. The electro-chemical bond is made because the ester molecule is polar. Sort of like a refrigerator magnet. It is attracted to metal and sticks.The PAO molecules are neutral and act like a piece of plastic placed on the fridge. They just fall off. All commercial jet plane flying, use an ester synthetic of some type and not a PAO. You need to run an ester of some sort for maximum protection.
There are some companies calling level 3 petroleum base stocks synthetic. This oil is a good Petro oil. But it is not what we call a synthetic. The end result is that some oils are labeled incorrectly and are very inexpensive.
Let’s explain why handling higher running temps is important.With petroleum oils there is a much better risk of failure from volatility problems than with synthetics. Why?
Have you ever burned butter while cooking? Yes, everybody has burned butter! The running temp or maximum temp is low. When butter reaches its maximum running temp it starts to evaporate (volatility) then it carbonizes and then it sticks to the metal pan. Now compare butter to vegetable oil in which you deep fry french fries. The only way to heat vegetable oil so hot as to make it carbonize, you would almost need a direct flame.
Petroleum oil is like butter as far as handling heat! Synthetics are like vegetable oil - synthetics won’t burn up and stick to your engine parts or go out the breather as fast as petroleum oils will. Remember esthers leave almost no deposits if they do burn this is the second reason to run a synthetic oil. Because you’re not supposed to have extreme heat problems everyday.
Old Oct 14, 2008 | 09:06 PM
  #34
notalk's Avatar
notalk
The Nissan Ester oil IS regular oil. It is conventional oil with (more?) ester additives.
Old Oct 21, 2008 | 04:02 PM
  #35
JohnEnglish's Avatar
JohnEnglish
Originally Posted by 04STi208G37
Please, section and/or page number. I don't recall reading this and I can't find it. Thanks.
In my 2009 G37xS manual it's page 5-15. It says something like "excessive acceleration and wheelspin followed by periods of hard braking will cause the car to go into "safe mode"." Then it tell you how to "reactivate" the car but if it doesn't work then you have to take it into a dealer.
Old Oct 21, 2008 | 07:52 PM
  #36
alunserjr's Avatar
alunserjr
How do you "reactivate" the car?
Old Oct 21, 2008 | 07:55 PM
  #37
JohnEnglish
I don't have the manual in front of me but it involved shutting it off and cycling though the start up sequence.
Old Oct 21, 2008 | 09:08 PM
  #38
04STi208G37's Avatar
04STi208G37
Found it
This is from the 2008 .pdf manual for the G37
"Fail-safe.
When the fail-safe operation occurs, note that
the transmission will be locked in any of the
forward gears according to the condition.
If the vehicle is driven under extreme conditions,
such as excessive wheel spinning and subsequent
hard braking, the fail-safe system may be
activated. This will occur even if all electrical
circuits are functioning properly. In this case,
push the switch to the OFF position and wait for 3
seconds. Then push the ignition switch back to
the ON position. The vehicle should return to its
normal operating condition. If it does not return
to its normal operating condition, have an
INFINITI dealer check the transmission and repair
if necessary."
Old Oct 21, 2008 | 09:34 PM
  #39
alunserjr's Avatar
alunserjr
OK, thanks. Doesn't appear to be related to the Torque Cut Control mentioned earlier - but interesting. Too much computer control!!!
Old Nov 4, 2008 | 05:15 PM
  #40
wiseman's Avatar
wiseman
Ive driven my car at high speeds, hairpin turns, heaving braking that actually broke my foot from the force of the stop... I was trying to avoid an accident when I guy jammed on his brakes. Ive never had this limp mode kick in. My engine went this week...
Over the past 10 months 20K miles Ive put in 20 +5 (original fill)= 25 quarts of oil. I do lots of city driving, than higher speed driving once the traffice lets up. I happen to think the car does not function properly when the engine is cold (reason they need ester) and at higher temperatures. My 2004 6mt with the brembos went through lots of oil but not nearly as bad. I am shocked your cars shutdown...
Old Nov 4, 2008 | 06:57 PM
  #41
notalk's Avatar
notalk
Please explain why additional ester additives might be needed when the engine is cold.
Old Nov 5, 2008 | 06:32 AM
  #42
alunserjr's Avatar
alunserjr
Wiseman, when you say your "engine went this week". Do you mean your G37's engine is destroyed in some way?
Old Nov 6, 2008 | 01:36 PM
  #43
DetroitG37Joe's Avatar
DetroitG37Joe
Well maybe by regular he meant the regular conventional with less or no ester additives - which is what they put in unless you request ester oil or have the VVEL knock TSB performed.
I'm starting to think a synthetic like Motul 8100 would be the best for our motors since our VQ's have a fetish for ester-based additives. Motul 8100 is ester-based.
Old Nov 7, 2008 | 03:19 AM
  #44
shabbo's Avatar
shabbo
do you mean that the engine blew up or something without ever engaging in limp mode?
Old Nov 23, 2008 | 10:16 PM
  #45
Lastchance's Avatar
Lastchance
Its Nov 23. I had a track day at California Speedway in Fontana, CA. I didn't hit limp mode all day. It was about 73-77 degrees. I'm not sure if going to Technosquare for another reflash had anything to do with it. I was taking my car up to 8k rpm's at times.
