Forged Performance: 2008 G37 Coupe Baseline Dyno
Old Oct 9, 2007 | 08:44 AM
IP37's Avatar
IP37
Originally Posted by solopresident
whta springss did u use?
g35 tein springs i believe
Old Oct 9, 2007 | 12:40 PM
iansw's Avatar
iansw
Probably not fully broken in yet - The chart above says 249.3 - That would be 274.23 with 10% added.....seems a little low still.
How many miles on it?
Old Oct 9, 2007 | 01:20 PM
chilibowl's Avatar
chilibowl
How the hell did 'Automobile Mag' achieve 287WHP, 53WHP more than an 07 G35 Coupe on their dynojet? Something seems off....even after the 10% addup
Old Oct 9, 2007 | 02:24 PM
COUPE-DADDY's Avatar
COUPE-DADDY
A wise man once told me. "Numbers don't lie, but you can get them to say anything you want". Trying to compare results from different dyno's is like comparing apples and oranges Too many variables.....
Old Oct 9, 2007 | 02:28 PM
court's Avatar
court
this is true but a 50ish hp difference is tNOT normal. something is wrong here???
Old Oct 9, 2007 | 06:14 PM
mal_TX's Avatar
mal_TX
Yeah, we would need to see how an 07 G35 Coupe dyno'd on this same dyno in order to make an equivalent comparison.
Also, the OP said the car has aftermarket wheels. If they are bigger or heavier than OEM it will read as a WHP loss, right?
Old Oct 9, 2007 | 09:23 PM
COUPE-DADDY
It really depends on what dyno they are using/correction factors/weather etc. If the dyno reads 10% lower than a dyno jet then the numbers don't sound bad for a "tight" motor.
Old Oct 9, 2007 | 10:31 PM
UNV-IT46's Avatar
UNV-IT46
which springs where used? what offset volks are those? seem kinda high considering the small amount of dish
Old Oct 9, 2007 | 11:51 PM
DiabloM3's Avatar
DiabloM3
Originally Posted by sharif@forged
We've been so busy, and havent had a chance to share our latest baseline results with the new G37 Coupe we aquired two weeks ago. The plan for this car is forced induction, naturally, but we wanted to get a baseline before starting to tear apart the car.
First off, I think the car looks much better in person, and although the rear is questionable to some, it really is starting to grow on me.
So far, we've added a set of Volk GT-F's, and a set of lower springs. More to come later. Compared to what we are used to tuning, the car is slow, but handles much better than a stock G35 or stock 350z.
Here are the dynos, and I will be posting some pics of the car shortly. For reference, a bone stock G35 Coupe just did 213whp on our dyno today. The heartbreaker strikes again! Add about 10-12% to simulate a dyno jet number.
can you get different Volks?
Old Oct 10, 2007 | 01:40 PM
sahiwal007's Avatar
sahiwal007
more pics please
Old Oct 10, 2007 | 07:57 PM
Deang35c6's Avatar
Deang35c6
The first gen G35 manual had about 18% drivetrain loss, so that would be 270 rwhp from 330hp. Basically, it's only a 21 rwhp difference, which is acceptable between dynos. I can also attest that the DD dynos read about 10% lower than a dynojet. I have a 9 psi Vortech only making 345 rwhp on a DD, when most guys with this setup get around 365-375 on a Dynojet. The DD simulates load
Old Oct 24, 2007 | 04:14 AM
Ga3ngs7ar's Avatar
Ga3ngs7ar
drop looks nice
Old Oct 24, 2007 | 09:59 AM
gspotter's Avatar
gspotter
Wheels are not aggressive enough. Good luck with everything!
Old Oct 24, 2007 | 02:26 PM
  #29
sharif@forged's Avatar
sharif@forged
Bone stone 03-06 g35 does about 212whp on our dyno. The 07 rev-up does 220whp on our dyno. Our dyno reads low...much lower than a DynoJet, and much much lower than a Dyno Pak. Take the number for what they are worth...just a simple comparison based on other cars we have tested on our Dyno Dynamics.
Old Oct 24, 2007 | 02:27 PM
  #30
sharif@forged
Thanks, I am waiting for someone else to become more brave with offsets. I was all on my own, in selecting them.
