G37 tune
G37 tune
I’m getting uprev tune in a couple weeks and I was seeing if there’s anything else I should add to my car for more power and louder/ more consistent noise level before I get the tune. I have k&n cold air intake, borla cat back exhaust system, and street demon muffler tips. Thank you
There are a lot of things you can do but first do some research. Here's a good place to start: https://www.myg37.com/forums/newbie-...read-this.html
It all depends on your budget and what you're looking for. Don't expect much of a bump from a tune with just an intake and exhaust change though. If you're planning on doing more performance mods then do that first otherwise you'll be back paying to get it tuned again.
Test pipes or high flow cats is going to net the most power. If that's not in your future plans then move on with the tune and inquire about the ARC upgrade for the Uprev tune. Allows for multiple maps and allows the tuner to use timing tables vs. burn tables which will result in a more proficient tune.
I'm not familiar with Magnaflow on the G. You don't see that much here. As a general rule, I'd shy away from "universal" exhaust parts, and instead target proven setups, like jpowersjr2 just said.
I'll also add that yeah it'll be louder but look up clips on exhaust rasp. That's going to be a lot of the noise you hear and most aren't happy with it. If that's not the noise you're looking for then go with Fast Intentions resonated high flow cats.
Hayabusa02
16
May 27, 2010 02:15 PM
