ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
Review Default Visconti Tuning - EcuTek Tune Promotion
Old Oct 20, 2015 | 09:23 PM
warpeacelove's Avatar
warpeacelove
Until March I'm going to be running a pretty awesome EcuTek tune promotion for the both the 370Zs and G37s.
Two Free Naturally Aspirated Tunes for every year of the 370Z & G37.
One tune will go to a 370Z and the other to a G37.
You will get a free EcuTek Programming License and custom pumpgas tune from me. Dyno Time NOT included. Cable NOT included.
Anyone that's not local to me will need to purchase a EcuTek cable to participate - I do NOT loan cables.
If your interested please email me at John@vtune.us.
Available Tunes:
370Z
2009 TAKEN
2010
2011
2012 TAKEN
2013
2014
2015
__________________
John@vTune.us
EcuTek Master Pro Tuner
== ECUTEK ==
There are two different versions of ECUTEK software:
ProECU - Tuning Suite - you want this version
ProECU - Programming kit not avail for 370z
Moving right along, there are a further two versions of the Tuning Suite software.
Off-the-Shelf Tune
Suitable for a 370Z/G37/Q50 w or w/o a cat-back exhaust and stock-sized intakes.
Custom Tune
Suitable for any modded 370Z/G37/Q50.
Fine-tune adjustments based on datalogs generated while on the street or dyno.
1. Off-the-Shelf Tune
- Price: $650
- Features:
Raises RPM Limit
Improves Fuel Economy
Adjusts Ignition Timing
Adjusts VVT Timing
Removes Speed Limiter
Raises MAX Cruise Control Thresholds
RaceRom Launch Control
RaceRom Flat Foot Shifting
Four Way Map Switching - 2x 91OCT & 2x 93OCT Maps
2. Custom Tune - RaceROM
- Price: $850
- Features include all of the previous ^^, plus ++:
Map Switching - Rev counter indication of the four different map switch modes
Speed Density - MAP sensor based tuning with VVEL compensation
RaceROM Controller - Use the cruise control switch gear for adjusting calibration
Knock Warning - Check engine light flashes when knocking is detected
Per Gear Rev Limit - A customizable Rev limit for each gear
Launch Control - Adjustable Launch RPM using the cruise control (Manual Transmission models only)
Traction Control - Adjustable traction control using custom maps
Boost Control - Closed loop boost control using custom maps
Flex-Fuel - Ethanol flex-fuel tuning using custom maps
AFR Control - Closed loop target AFR control using custom maps
Fail-Safe - Protect the engine from any dangerous situations
Gauge Hijack - Display lambda, AFR, fuel trims or ethanol content on the oil temp gauge
If the Custom features are something you NEED. Then tell your tuner you want THAT version.
The Off-the-Shelf tune, does NOT include all features.
Old Oct 20, 2015 | 09:26 PM
warpeacelove
here are a few new features from EcuTek
EcuTek RaceRom 4-WAY Map Switching
Old Oct 20, 2015 | 10:14 PM
jroyalty7's Avatar
jroyalty7
So by the 2012 slot marked as being taken is that for both the 370 and g37? Or is it still open for a g37? And where's the original posy on this locates if you don't mind
Old Oct 21, 2015 | 12:18 AM
warpeacelove
I think it is still open. I would suggest emailing him.
Old Oct 21, 2015 | 02:12 PM
warpeacelove
Where you able to reach him?
Old Oct 21, 2015 | 09:16 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
Isnt this thread like 2 or 3 years old.. from what i read on the 370z forum this deal is no longer
Red00lght
Jan 4, 2016 08:56 AM
infamouslkv
Oct 24, 2015 02:11 AM
Zukauskas
Buying & Leasing
Oct 17, 2015 09:30 PM
Ihveeun
Oct 15, 2015 08:02 PM
Detailed Image
Lighting/Cleaning Products
Oct 14, 2015 12:53 PM
