question? about my g35
Old Jan 3, 2007 | 06:50 PM
kpopseven's Avatar
kpopseven
after i had install a new short air intake
the car started to make rattling noise for 0 rmp to 1300rmp
then it runs smooth
it keeps doing that and i have no idea wtf is going on ..
can yall help me out?
Old Jan 4, 2007 | 04:49 PM
izmir41500's Avatar
izmir41500
what intake is it? did you check all the connections and make sure it's not hitting against something?
Old Jan 5, 2007 | 09:55 AM
JD_AND_DA_G_RIDE's Avatar
JD_AND_DA_G_RIDE
then it runs smooth
Could be hitting your a/c line...
Old Jan 5, 2007 | 01:45 PM
eemon10
Guest
Posts: n/a
i had the same problem...its hitting your engine cover...i just put a rubber piece under the engine cover and problem solved
Old Jan 5, 2007 | 02:22 PM
kpopseven's Avatar
kpopseven
should i worry about it tho?
Old Jan 5, 2007 | 02:24 PM
Nismo G's Avatar
Nismo G
Just take your engine cover and throw it in the closet, its a heat trap anyways, with that thing off your engine will breath better for sure. Once that is off you should be fine no issues.
-sean
Old Jan 5, 2007 | 04:51 PM
eemon10
Guest
Posts: n/a
no...either take the cover off...or put a rubber piece under it just to elevate it a little...thats wat they did to mine at Z FEVER
Old Jan 11, 2007 | 03:32 PM
g35rcr's Avatar
g35rcr
what intake system did u install
Old Jan 11, 2007 | 03:38 PM
gary c's Avatar
gary c
Questions.................
Actually your engine cover is a heat trap. It confines the heat from your
plem so removing it will be good for your G. Mines in a plastic bag some-
where in the garage..........
Mark350GT's Avatar
Mark350GT
also i would check to make sure the intake is not touching the ac line.
jfisher
Apr 25, 2017 01:22 PM
drewfinity
Sep 24, 2015 11:01 AM
xnick101
Intake and Exhaust
18
Sep 16, 2015 12:02 AM
Clutch34
Sep 14, 2015 03:26 PM
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
