DIY: The Headlight Full Monte: Strips, Halos & Demon Eyes
Old Dec 31, 2019 | 12:39 PM
  #31
bikezilla's Avatar
bikezilla
Originally Posted by 18 g37
Nice DIY.
Just wonder if you upgrade the bulbs to led?
I think if the headlight bulbs updated, it will be perfect.
Which bulbs? Do you mean in the Citi/parking light cell?
Or the turn signal?
the headlight xenon so that stays as is.
Old Dec 31, 2019 | 12:40 PM
  #32
bikezilla's Avatar
bikezilla
Originally Posted by ZG37XCoupe
Just went through the entire DIY... I will NEVER complain about the price of custom headlights again!
Seriously though, great DIY and kudos to you for all of the effort in wiring everything so thoroughly!
Thanks it really was a journey!
Old Jan 14, 2020 | 01:44 PM
  #33
AirJoe's Avatar
AirJoe
Halo Installation
Does anyone know of a good installer in the Dallas/Fort Worth area?
Old Apr 15, 2020 | 11:01 AM
  #34
Asafzabari's Avatar
Asafzabari
Does anyone knows why when I use 1500 grit wet sending paper it looks like the clear coat is removed and is some points even the black color....
Old Jul 11, 2024 | 08:59 PM
  #35
wearwolfzw's Avatar
wearwolfzw
Originally Posted by bikezilla
Main wiring
Wiring up was a lot of work as well.
I ran the two halos, DE and SSBT from the passenger side to the driver's side and bundled and connected the harnesses, converters, and drivers in the space above the driver side fog lamp. The passenger side has a washer resivoir so this side was better go collect all the gear.
Attachment 130013
Attachment 130014
I taped all the connectors just to be sure and zip tied all the loose bundles.
Also I had intended to enter the cabin on the driver's side with the wires for the bluetooth controllers and power taps, but it's virtually impossible to snake a wire through the main driver side harness boot beneath the power brake gear. The wire bundle in the boot is too thick and the angle into the cabin is too tight.
So I routed the wires inside the upper fender, across the power brake compartment, under the windshield cowl, and into the harness boot on the passenger side.
Attachment 130015
Attachment 130016
Attachment 130017
Attachment 130018
This left the control and power wires behind the glove box, I secured and connected the bluetooth controllers there, and ran the power lines across through a gap behind the cener console, underneath the steering column and into the fuse panel. I used micro fuse taps. one for always on to drive the SSBT so it can function as a hazard signal even when the car is off. And one for Acc-on power to feed the halos and DEs only when the acc or ign is on.
Attachment 130019
I also added one switches to each so I can disable the white SSB drl function at night and I can disable the halos and DEs' during the day. Having a quick kill on the halos removes the worry about remembering to use the bluetooth app to turn the halos off. It's not recommended have the halos on with the headlights (probabably because of the projector heat) and I don't want to wonder if I took off a flashing color mode that could get me pulled over.
Attachment 130020
I do sometimes drive with the halos on in solid white mode.
Fins.
Attachment 130021
Attachment 130022
Attachment 130023
Attachment 130024
Attachment 130025
wow, just wow, I am blown away by not only how great of a write up this is but the attention to detail, the thorough specifications, and how great they turned out, kudos to you. I know this was a while ago and an old post, but majorly impressed gj! 👍👍
grailedmund
Aug 15, 2019 07:55 AM
ONEighty
Picture Share G Coupe
233
Nov 4, 2016 04:00 AM
seungmoon
Nov 8, 2008 02:57 PM
jock_3101
Oct 24, 2008 02:42 PM
ncplay13oi
18
May 30, 2008 04:55 PM
