Morose oil air separator/catch can
Old May 30, 2016 | 08:28 PM
turbohounds's Avatar
turbohounds
I haven't seen a thread yet with the Moroso universal 85474 air oil separator. I was having a bit of rough idle fixed by cleaning the throttle bodies. Not wanting to have this problem again I decided to install a catch can. The Moroso unit isn't the cheapest, but is well built. The hose with the kit would be long enough for the stock G37 manifold, but since I have the Motordyne manifold I had to but a longer hose.
After ~1 month of use, I had at least a tablespoon of oil collected. Definitely good not to have that in the intake.
I had to make a custom bracket that I thought might be helpful for others to see. It fits to existing bolts by the radiator, just needs one longer bolt and nut to connect - see picture 2.
Connections are the same as others - tee into two lines in front of the manifold, and for the motor dyne, return one line to the back of the manifold.
Custom bracket
Bracket in place
Separator installed
JerseyG
NorthEast
Feb 12, 2015 10:11 PM
NightInSeoul
Southern California
Oct 21, 2013 12:59 PM
Soarar
Northern California
May 26, 2011 05:26 PM
jedmonds
Northern California
May 9, 2008 01:10 PM
