DIY: Hood Strut Replacement.
Old Sep 2, 2013 | 07:10 PM
quakerroatmeal's Avatar
quakerroatmeal
So like many other owners. I got tired of my G abusing me by smacking me in the head with its hood. So I decided to change out those struts. While at it I decide to make a DIY with before and after video as well.
Difficulty: 0-5 ; I'd rate these like a -5 in difficulty, yes a negative 5 it's that easy. I thought you need a friend to hold the hood but I just held it with my head while I pop in the new strut.
Tools needed: Small Flat Head.
Here's a full view of the hood strut
There are clips on both top and bottom of the strut holding it in place. Both have indention's to where you can place your flat head.
When you lift the clip with the flat head you just push it to the side and it'll pop off the ball joint.
Same thing with the bottom
Now the new struts they just pop onto the ball join. Put the bottom portion on first than clip the top strut in. Same thing for other side and you're done.
Before video with old struts
http://s48.photobucket.com/user/shyb...662eb.mp4.html
After video with new struts
http://s48.photobucket.com/user/shyb...0a356.mp4.html
These are NOT OEM struts, they're actually aftermarket custom struts that I had a friend source for me. I do not have any information about them at the moment. They are a lot stronger lift than OEM that's for sure.
Old Sep 9, 2013 | 11:55 PM
dtran2714's Avatar
dtran2714
This is where got mine--> <a href="http://www.ebay.com/itm/2-FRONT-HOOD-LIFT-SUPPORTS-SHOCKS-STRUTS-ARMS-PROP-RODS-DAMPER-/161100844039?pt=Motors_Car_Truck_Parts_Accessories &fits=Model%3AG37&hash=item25825bcc07&vxp=mtr">Eba y HOOD DAMPER</a> I will test it out when I get my car back from the shop.
Old Sep 11, 2013 | 02:20 AM
quakerroatmeal
Post how good they are dtran. If anyone is interested in ones I have shoot me a PM.
Old Sep 14, 2013 | 06:13 PM
dtran2714's Avatar
dtran2714
I just installed them today. They work like their supposed to. It's just feels a bit stiffer than OEM, but other than that it's good as new.
Old Sep 15, 2013 | 03:31 PM
SgtGoldy's Avatar
SgtGoldy
Anything bad to say against them? For the price I am a bit on the fence as far as quality of the build....
Old Sep 15, 2013 | 03:44 PM
quakerroatmeal
Post up a video. Curious see how they compare.
Old Mar 30, 2018 | 09:48 PM
Infinibini's Avatar
Infinibini
Hot dang! That was so EASY!!!
I just did this today and I can't believe how easy it was. If I knew it was going to be that easy I would have changed them a long time ago. It took about 60 seconds. I got two struts from RockAuto for $12.50 each, and all I had to do was pop the old ones off with flat head screwdriver. It took zero effort.
Striderx88
Oct 10, 2015 10:42 PM
si_driver
Sep 30, 2015 11:46 AM
BurtoN86
Sep 30, 2015 03:32 AM
dedmanchan
Sep 24, 2015 11:25 PM
acthesquid
General Tech Questions
Sep 15, 2015 07:31 PM
