Takeda Intake Parts
Old Apr 11, 2013 | 05:21 PM
nbast's Avatar
nbast
Takeda Intake Parts
I recently purchased a used Takeda intake. It's in great shape, but there are some small parts missing.
The MAS Sensor gaskets and the screws needed to mount the sensors. Screws should be easy enough to acquire locally, but I'm not sure about the gastkets. It shouldn't be difficult to make a pair, but I don't know whether they're rubber, foam, or something else. What kind of material are they made of? If anyone has the exact screw type I should look for, that would help as well.
The parts are labelled Q and R in the manual.
Manual is here: http://afepower.com/catalog/TA-3016P/is.pdf
Old Apr 11, 2013 | 06:07 PM
ZOSTER33's Avatar
ZOSTER33
You should be able to use the stock screws and they are just foam gaskets with adhesive on one side. You might be better off making your own. Hope this helps.
Old Apr 12, 2013 | 02:26 PM
nbast's Avatar
nbast
I'd really appreciate it if someone could point me at a gasket material that can take the heat of being right next to the engine and won't deteriorate over time.
I found some things that looked promising, but then I noticed the 'up to 250 degrees' notation in small letters. I don't know how hot it will get, but I'd think it could get a lot hotter than that, especially on the track.
Old Apr 15, 2013 | 12:08 PM
nbast's Avatar
nbast
I called AFE and ordered a pair of gaskets. A few more dollars of worth the piece of mind know that I have the right parts...
j50ny
Jul 21, 2017 10:46 AM
OneSickBlackG
Jan 6, 2016 08:49 AM
luisalan
Sep 6, 2015 05:45 PM
