DIY: Aero / IPL sideskirt install.
Old Sep 3, 2012 | 10:32 PM
Zydan's Avatar
Zydan
Originally Posted by myk1013
I broke most of the clips when I pulled out the second skirt. The plastic may have gotten brittle from 4+ years of 90deg.+ weather.
My car is only like 2 months old, and my clips were breaking left and right, so I dunno.., mine were just regular side skirts, so in the trash with them!
Old Sep 4, 2012 | 05:37 AM
emyrl's Avatar
emyrl
The clips are complete trash, parts department at the dealership told me they're really just for one time use. You're lucky if the clips don't break on you. And also be careful about yanking too hard, you can also break the tabs on the stock sideskirts itself.
Old Sep 4, 2012 | 12:36 PM
myk1013's Avatar
myk1013
Thats what happened to mine, broke most of the tabs on the driver side skirt. It's probably un-reusable anymore.
Old Sep 4, 2012 | 01:31 PM
emyrl's Avatar
emyrl
Yea, definitely not reusable if you pull them straight out. If you actually want to save the clips from breaking you have to rotate the clips before pulling them out. That takes up much more time, but does save you some money (those clips add up at the parts department) if you ever want to reuse the clips.
Old Sep 4, 2012 | 02:03 PM
myk1013's Avatar
myk1013
You have a VR with AK-X front right? Could you post a current pic of your ride?
Old Sep 11, 2012 | 12:20 AM
LftSdDrv's Avatar
LftSdDrv
Just noticed one of the bolts on each side is different. I believe its the one all the way up at the front of the skirt.
Old Sep 20, 2012 | 07:14 AM
G37-Pearl's Avatar
G37-Pearl
awsome writeing
Old Sep 23, 2012 | 03:30 AM
kkokko's Avatar
kkokko
Hey,
I just installed the aero sides!
Couple of things though, this DIY doesn't include removing the diffuser did you guys not have to do that?
Also that white piece was a PITA to remove, but the kit came with the light blue grommet and instructions to remove that as well. I did that but managed to break the original grommet and it fell into the hole!!...
Doesn't look like there is an easy way to get the bit of plastic out... hope it won't make any rattle sounds..
Old Sep 23, 2012 | 11:13 AM
soolman32's Avatar
soolman32
Great write up! I will definitely get some use out of it.
Old Mar 10, 2013 | 08:24 PM
ktak's Avatar
ktak
Pictures are down, is there anyways you can post'em up again?
Old Mar 10, 2013 | 09:00 PM
Yang88she's Avatar
Yang88she
Not that hard to do, just make sure all you bolts are off underneath
Old Mar 12, 2013 | 11:40 AM
myk1013's Avatar
myk1013
give me a day or 2..... I'm a bit busy right now..need to look for the pics.
Old Mar 12, 2013 | 07:06 PM
ktak's Avatar
ktak
Yep, I got it done w/out pics. That 'grommet' clip was really pain to pull out. Had to tie a shoe lace around the pin part and pull with all my weight (rolled backwards and fell into a bush lol). I think you forgot to mention a step to remove the 'diffuser flap' that's attached at the end of the side skirt (or maybe i didn't have to remove it?) Thanks for the write up!
Old Mar 18, 2013 | 12:25 PM
  #29
Himalaya's Avatar
Himalaya
reupload pics please
Old Apr 24, 2013 | 12:22 PM
  #30
jayrdong's Avatar
jayrdong
Wait, are the IPL side sills not just direct bolt-on on top of the existing sides? Do you have to remove the factory sides, then install the new IPL side sills?
