DIY: Paint Your Calipers
Hey guys I have a question I need some help answering. I sanded the cals down to the bone (just cause I wanted to...well and I got a bit too aggressive with some low grit sandpaper bc the front calipers had banged against each other pretty hard 6-8 times during transit. Anyway I just completed the three coats of primer and I'm letting it set for 24 hours at the moment. All four look well and don't seem to have any issues but I think a couple very small spots may need some light wet sanding. So here's my question---should I take the cals down from the hanging/painting booth and do a bit of wet sanding before I begin the coats of anodized red? Or will these very minor dots n funky dink marks be something I can easily wet sand out after I put the multi-coats of color on???? Thanks in advance.
Ok painting question guys help me if you know the biz. I've been prepping n painting my BBK and I chose anodized red. The color seems to be coming out a shade (or 3) darker than I'd like. Is there any other color of paint I can add to the mix to lighten or brighten it up a bit. I just finished my first 3 coats of the AR. I can post pics of anybody wants to see em. Let me know PLZ
FYI I still have another can of the ADR. Plus the expensive clear coat to add. Am I trippin and should just wait to check out results after clear??? I don't hate the color but it doesn't look like the can top. Pretty sure I didnt overspray or anything like that. 7 days till I can throw a new coat on. Really don't wanna have to sand the b!tches down again so plz save those responses. Plz
The clear will make the color pop a bit more but not really lighten it.
What color did you paint over? What I mean is if you used a dark primer, that can make your paint a shade darker, especially if your red is semi transparent, like an anodized color would be. I that's the case then take it back down to zero and spray again or lay down a silver base then the red.
I can't post pics for some reason. You should pm blnewt he will hook you up with a thread link. Same one I used throughout the whole project.
Basically just run the wire thru the little holes on the backside of the caliper where the pins go thru, give the wires some twisting to protect your babies from falling, and attach the other end to something stationary (like a closet shelf, your garage door chain, or buy a few hooks that screw into the wall- ceiling in this case). I hope this helps some. Pm me your numver I'll gladly text you pics of my whole setup.
