DIY: Bumper Plugs
Old May 8, 2011 | 08:08 PM
breftayka's Avatar
breftayka
Bumper Plugs
I got my information from G35driver, but thought I would bring it over here too.
I found my bumper plugs in the hardware drawers at Lowe's. They were in the drawer labeled "Hard to Find - Nylon Hole Plugs."
All you need is some touch up paint for your color car (Dealer), some nylon hole plugs (Lowe's), some clear coat, sandpaper, (Anywhere), and a knife or razor.
I used 3/16 hole plugs, but if your bumper holes are bigger, use a bigger size. (You may choose to use a drill or a Dremel and go one size bigger, with the plugs, than the drill bit you used. This will allow you to skip the guessing part.) You want the plugs to be too big too start out, but only barely. Use a sharp knife or razor to bore out the hole just enough to fit the plug.
Sand the tips of the plug so that it is smooth and will hold the paint better. Use rubbing alcohol to clean off the residue. Let it dry for about a minute. Now you can lay your first coat on the plugs. Use as many coats as necessary and let each coat dry for at least 30 minutes. Finally you can spray a couple of coats of clear to finish.
Now you can push your plugs into the holes. You want a tight fit, so the plug will not fall out.
Edit: Added some extra input from fellow members.
Old May 8, 2011 | 08:37 PM
You may want to mention to drill the holes out to a specific size so that they are uniform in size and perfectly round, and also so that you know exactly what size plugs you'll need to buy.
Old May 8, 2011 | 08:39 PM
breftayka's Avatar
breftayka
Yeah I didn't have to do either. I eyeballed the hole size and went into Lowe's and got 2 sizes that I thought would be closest.
I don't see the need for drilling as I never had to. The knife helped open the hole up just enough.
Old May 8, 2011 | 08:49 PM
Sure. But if you drill them out to a specific size, you don't need to cut anything, guess, buy several sizes, or eyeball and they'll fit perfectly the first time without any doubt. But if guessing works for you that's cool too. It's only a suggestion for those who want to do it easier and get it right the first time.
Thanks for posting the info.
Old May 8, 2011 | 09:47 PM
breftayka's Avatar
breftayka
Yeah I know what you are saying, but I wasn't sure if could chip the paint. The plugs were $1 a pair. I didn't have to open the packs to check either. The other diy said to use 7/16 but I could tell they were much more than I needed. I really didn't cut anything. I put the knife in the hole abs made one turn which made it just right.
I know many people have used a drill and had good results too. Thanks for your input!
Old May 8, 2011 | 10:25 PM
P Casey's Avatar
P Casey
Good info bro I need to do this, along with a motorized plate
Old May 8, 2011 | 11:28 PM
CDONNS's Avatar
CDONNS
I used a dremel bit to drill out the holes a bit. Funny, I actually have them out on my coffee table drying at the moment, had to put another coat on after about 6 months.
Old May 9, 2011 | 07:42 PM
Djfarhan's Avatar
Djfarhan
i am gonna be doing this soon when i get my show n go in!
Old Jun 18, 2011 | 07:45 PM
hobbs's Avatar
hobbs
FYI, if you run without a front plate in California, when you go to an airport be sure to attach one temporarily as Homeland Security scans incoming vehicles and you will get a ticket. This is really bad at LAX.
I always tell the dealer if the bumper has holes I will not buy the car.
Old Jul 1, 2011 | 02:00 PM
Xenolith666's Avatar
Xenolith666
I had the front bumper plate in Virginia, once I moved to Florida I didn't need it anymore and removed it. I rolled into the nearest Infiniti Dealership and they plugged the holes for free.
2K1 6T8
Oct 6, 2015 07:40 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
botlfed98
Sep 29, 2015 12:07 PM
Chappedj
Sep 28, 2015 03:20 PM
