Question on Paint Type for Grille
Old Aug 18, 2009 | 11:04 PM
dnedawg's Avatar
dnedawg
I am looking to paint my gille and I know that some of you have taken to a paint shop and had it done, but most have done it themselves.
For those who have DIY-ed it what type of paint did you use?
Old Aug 18, 2009 | 11:42 PM
SkyzDaL1m1T's Avatar
SkyzDaL1m1T
most use duplicolor spray cans themselves but if you need i did several of the LAG's grilles myself professionally any color gloss black, colormatched, etc. just shoot me a pm
Old Aug 25, 2009 | 04:33 PM
bran1093's Avatar
bran1093
Krylon Plastic Fusion Worked fantastic for me. The nozzle is sweet too.
Old Aug 25, 2009 | 08:46 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
i used duplicolor primer, black, and clear coat and it looks AMAZING. you'd think it had been OEM color matched. plus it took $20 and an hour
Old Aug 25, 2009 | 09:29 PM
WhosUrBuddiee's Avatar
WhosUrBuddiee
I went to a local paint shop and had them spray it for me.
Old Aug 25, 2009 | 09:43 PM
dnedawg's Avatar
dnedawg
how much did the paint shop charge?
Old Aug 25, 2009 | 10:29 PM
klossfam's Avatar
klossfam
Rustoleum Sandable Black Auto Primer (#249418)
Rustoleum Metallic Enamel Finish "Black Night Metallic" (#7250830)
Rustoleum HIGH PERFORMANCE WHEEL CLEAR COAT (#248929)
The clear coat above is tougher (basically a little thicker finish) that standard clear coat enamels. It has held up well...No chips so far (600 miles or so since the grill paint).
Keep is good prep - some 400 and 800 grit sandpaper and A LOT of nice, thin coats.
Old Aug 25, 2009 | 10:35 PM
ElLayG37s's Avatar
ElLayG37s
osh brand primer, sand, water, clean
krylon black, sand/ w fine grit 800+, water, clean
1 more coat of black.
and finally 3 coats of whatever your choice clear, I went with krylon Satin clear.
Old Aug 26, 2009 | 10:28 PM
dnedawg's Avatar
dnedawg
Thank you everyone for your suggestions and responses. I finally got up the courage today to paint the grille myself and it looks great.
Of course on the way home from work to paint the grille a dump truck in the right lane hits a barrel, the barrel bounces off the retaining wall on the right side of the road and rolls into th center lane were I am. I slam on the breaks and hit the barrel. So the whole way home I am sweeting what the front of my car looks like. I'm on I95 and not stopping to check. When I get home I look and relief, no damage! So plans to paint the grille were back on! I love the finished look!
Old Aug 27, 2009 | 06:09 AM
hispeed-lowdrag
^+1 congrats! It looks great. And that is definitely good to hear that there was no damage!! I had a school bus drive me into a curb so I know the feeling of dread when you hit the barrel.
Old Aug 27, 2009 | 08:30 AM
WhosUrBuddiee
I also did a custom emblemless grill. But just for paint, you can expect to spend about 50-100 dollars.
Old Aug 28, 2009 | 03:28 PM
Raizon's Avatar
Raizon
Do you sand the grille in between coats of primer and color paint?
Old Sep 11, 2009 | 12:39 PM
Jakex1's Avatar
Jakex1
no u just sand off the original clear coat/paint. Whole point of primer is to make the paint stick.
jaylock92
Apr 22, 2022 12:39 PM
vquezada24
Aug 24, 2015 04:32 PM
waitwhat
Aug 19, 2015 09:47 PM
