OEM 18's discolored
Old Aug 20, 2019 | 07:25 AM
Snaoum's Avatar
Snaoum
OEM 18's discolored
So a while back I washed my car at home as always. Having a hard time recalling what I sprayed the rims with, it was either Nick's Professional All Purpose cleaner or some Iron-X product possibly by Adam's Polish. Anyways, shortly after, maybe the next I think, I noticed black spots on all 4 rims. It looks like a discoloration of some sort. Is there anything I can use or do at this point? I am not sure what happened, I have am leaning towards the Iron-X product to be the culprit. It almost looks like it ate in some spots the finish. Wheels are the OEM 18" duckfeet.
Old Aug 20, 2019 | 08:55 AM
BULL's Avatar
BULL
Moderador
Same here, oem colors are 3 stage paint and default to black once initial coatings have been eaten by harsh products. Meguiars wheel cleaner (Purple bottle) is what i've resorted to.
Unfortunately there is nothing you can do but to paint them. Sorry.
Old Aug 20, 2019 | 03:23 PM
Surfnazi's Avatar
Surfnazi
Did you let brake dust sit on wheels long? And did you rinse wheelnoff first before using caustic cleaner on them
Old Aug 20, 2019 | 04:29 PM
BULL's Avatar
BULL
Moderador
What ends up happening is a harsh reaction to the iron. The issue here could have been the temperature of the wheel.
Anything you spray on a hot wheel will stain/damage it.
Old Aug 23, 2019 | 02:34 PM
Surfnazi's Avatar
Surfnazi
Have you tried using polishing compound on it to see if stain will buff out or even tooth paste
Old Aug 23, 2019 | 04:08 PM
BULL's Avatar
BULL
Moderador
The black that you're seeing is not a stain, this is the base that it's painted on the Wheel. For the wheel to have this color and needs to be painted black first and then it receives multiple Coatings silver and it's finalized with clear. If you're seeing black that means there is no more clear and no more silver polishing compound toothpaste or anyting will only affect the black if it removes the black you'll be left with aluminum. I'm sorry but only repainting will take care of this issue.
Old Aug 24, 2019 | 05:20 PM
Surfnazi's Avatar
Surfnazi
The 19inch wheels are very close to liquid graphite touch up paint, I've used it and you can tell if you take time and use a toothpick
killingforpeace
May 3, 2016 08:05 PM
eskalaid
Dec 22, 2015 03:07 PM
onthefence
Jan 5, 2014 10:46 AM
blkmanual
Nov 1, 2010 03:36 PM
