Going to Paint Correct
Old 06-19-2018, 11:24 AM
10infiniti37s
10infiniti37s's Avatar
I'm about to paint correct my sedan and was looking for a few last minute pointers. I've done a lot of research on products and techniques, but was looking for some stuff specific to our cars. I made a list of the process I will take, using some info from this forum, too (see below). I believe I read somewhere here that our paint is on the thinner side, and to be careful. I'll start with polishing compound before going with a stronger cut. I'm probably going to practice on another car first
Detail Process
1. (Take off front license plate)
2. Wash (Use Bug/ Tar Remover)
3. Clay w/ spray detailer (Straight Lines only)
a. Including Windshield
4. Rinse and Dry
5. (Optional: Clean Exhaust tips with Metal Polish)
6. Spray with Water and Rubbing Alcohol Mix
7. Tape windows/ Trim
a. Also tape edges
8. Compound (Meguiars Ultimate Compound on CG Orange Hex Logic Pad)
a. Max speed 5-6; some pressure
b. Use distilled water to soften the pad before use
c. In between each panel, use a toothbrush to loosen the pad
d. Wipe with a microfiber
(Repeat the combo that works over the entire car. Do small areas, work slowly, take breaks, wipe away residue thoroughly. Other tips:
Switch pads as they get gummed up/saturated. They become less effective and residue begins to become harder to remove. This is why I recommend two or even threeof each pad. If you run out, wash one (soap and water), dry it by putting it on the PC, putting the PC in a bucket/recycle bin etc, and spin it up to speed 6; the water will flyout into the bucket.)
9. Finishing Polish (M205 Ultra Finishing Polish on CG White Pad)
a. Max speed 4; little to no pressure
b. In between each panel, use a toothbrush to loosen the pad
c. Wipe with microfiber
10. Wipe entire car using a mixture of Water and Rubbing Alcohol (70%) Mix w/ Microfiber
a. 50:50 in a spray bottle
11. Paint Sealant (CG Black Pad)
a. Speed 1
12. Wax
13. Quick Detailer if needed
Old 06-19-2018, 01:13 PM
Surfnazi
Surfnazi's Avatar
Buy extra mop heads and compound. Better to have extra then need more half way through. Always use wet head to keep from paint burn
Old 06-23-2018, 01:26 PM
Rollo
Rollo's Avatar
Not sure what sealant you are using but you shouldn't need a wax over it...unless you just like the looks of wax.
Looks like a solid plan...you should post before and after pics.
Old 06-23-2018, 03:44 PM
Surfnazi
Surfnazi's Avatar
Take your time have lights ready to spot onto areas you are working on
Paratrooper
10-09-2015 03:38 AM
yaoochi
02-03-2009 01:44 AM
hiyaku
08-18-2008 07:33 PM
mahroni
07-07-2008 11:22 PM
vINCe_Inc
Canada
02-11-2008 12:02 PM
Quick Reply: Going to Paint Correct
