Basic Carwashing Techniques - thoughts?
Old Apr 21, 2013 | 03:51 PM
LateralSpeed's Avatar
LateralSpeed
I was recently directed to this to care for my new G and followed most of the guidelines when washing it today and it turned out pretty good. The paint is in good condition, it just needs a good once over by a professional to tighten it up a bit from improper washes in the past.
What are your thoughts on the techniques here, anything you like/don't like or would add?
Attached 2 pictures(wifes car in the background), also any suggestions on the best way to remove that carmax sticker on the trunk?
Attached Thumbnails Basic Carwashing Techniques - thoughts?-rear1.jpg   Basic Carwashing Techniques - thoughts?-front1.jpg
Old Apr 21, 2013 | 09:58 PM
chris5o4's Avatar
chris5o4
I use the video as a template too. I just added another water bucket to the tire bucket so I don't apply old brake dust to the rims again. makes sense right? I usually follow up with a spray wax to have the water beading effect and smooth feel. As for the carmax thing I would assume it's like debadging.. I may be wrong, hopefully someone else will chime in with the correct information. Happy Detailing!
Old Apr 22, 2013 | 12:50 AM
amt120's Avatar
amt120
After you clean the car, try peeling it off. If you're having trouble, if you have a clay bar , runing the clay bar over the area with clay lube will help lift the sticker some. If you peel it off and there's some sticker residue, apply some goo gone and wipe the area after and you're good to go.
Old Apr 22, 2013 | 05:16 PM
DeepHouseGuy's Avatar
DeepHouseGuy
When I bought ,y maxima from carmax I said before I take this car off the lot you take that foolish sticker off! Hey obliged.
Old Apr 22, 2013 | 05:17 PM
g37flamer's Avatar
g37flamer
try using some heat as from a hair dryer to take it off i used a low heat gun to take the embels from the trunk
Old May 2, 2013 | 01:06 AM
OnlyNismo's Avatar
OnlyNismo
great video. thanks for the share! i need to change from a sponge and use the mitt and foam technique.
Old May 2, 2013 | 01:18 PM
rlo's Avatar
rlo
Pretty good video, although I try to do less drying by sheeting the water on the final rinse.
Old May 3, 2013 | 12:24 AM
enshadow's Avatar
enshadow
Looks like good techniques.
fuzzed
Aug 21, 2020 09:35 AM
04G35NYC
Jul 19, 2016 01:42 AM
Dillybar12
Nov 1, 2015 07:23 PM
Awgd8
Sep 30, 2015 06:22 PM
