Truth about bird poo, not corrosive?
Old Jul 23, 2011 | 05:15 AM
kkokko's Avatar
kkokko
What are your thoughts on this?
The truth about bird droppings – not corrosive, it seems
If the article is true, does that mean as long as there isn't high heat etching/staining won't occur?
Old Jul 23, 2011 | 05:19 AM
kkokko's Avatar
kkokko
Autoglym's research on Bird droppings throw light on paint damage | Auto Tech Blog
Old Jul 23, 2011 | 05:49 AM
TOGWT's Avatar
TOGWT
Always keep an open mind and I would also strongly suggest that you verify any information that I or anyone else shares with you. Be pro-active and research others opinions and products, test them and then make an objective decision based upon the factual information gained from research. Don’t regard any source as something you can entirely rely on, least of all marketing hype or brand loyalty
Commercialism brings with it concerns of honesty and true representation. In other words, it’s difficult to know what is true when someone is motivated by income, i.e. directly targeted at product sales, more so than an unbiased opinion. One of the advantages of being independent and not having to answer to shareholders
Most importantly - choose carefully whose advice you listen to, and more importantly what advice you act upon. The misinformation and myths that are so prevalent in the detail industry is the reason that detailers need to do research on their own. Treat all marketing claims as being just biased marketing claims and if you're lucky they will be based on truth and the company will operate ethically.
Here is my research on this subject-
Bird Excrement
Consists of [: Uric acid , C5H4N4O3 [a diprotic acid , thus in strong alkali at high pH it forms the dually charged full urate ion, but at biological pH or in the presence of carbonic acid or carbonate ions it forms the singly charged hydrogen or acid urate ion as its pKa2 is greater than the pKa1 of carbonic acid] [1]
Cause - the different types of food ingested by birds affect the composition and quantity of droppings. Chemical aggression on the paint surface is caused by strong organic acids acting for an extended period and exposed to high temperatures.
One of the most serious threats to a paint surface; it's not only disgusting - it's a toxic hazard. Bird excrement contains unpleasant fungi, including Histoplasma capsulatum and Cryptococcus neoformans as well as bacteria, including Chlamydophila psittaci. Migratory birds, especially seagulls are known to spread hard-to-treat infections as they can carry antibiotic-resistant bacteria.
Bird excrement is one of the most damaging environmental pollutants as they relate to automobile paint as it comprises; Ammonia and urine as white crystals of uric acid (pH 3.0 - 4.5) a small organic compound, which is produced by the breakdown of protein during digestion, and is excreted by reptiles and birds.
Uric acid is also the end product of nitrogen catabolism in birds Ammonia is a mixture of nitrogen gas and hydrogen gas; with moisture as a catalyst it becomes Ammonium Hydroxide, which is caustic.
When you have an acid + moisture +oxygen + ozone all of which equates to a highly concentrated acidic solution, add heat (reactivity) to this equation, and you have the causes of pitting, a concave indentation on the paint surface.
Heat and water act as a catalyst (reactivity); a vehicle paint surface temperature of >90.oF creates a very aggressive reactivity of the Alkaline, Uric Acid and Ammonia. This will cause surface etching, so they should be removed without delay. In this case, paint care not only serves aesthetics, but also helps preserve the vehicles. At lower temperatures (> 40.oF or less) there’s no reactivity and therefore little or no etching.
Be cognizant that there are no polymers, nanotechnology coatings or waxes that are acid-proof; they will only offer short-time resistance. The most pertinent factor is to have a layer of (sacrificial) protection between the acid and your paint surface. The second is to ensure that is removed and any residue is neutralized as soon as possible
phanman
Sep 22, 2015 04:51 PM
