Drying a black G37 after wash
Old Mar 30, 2011 | 04:52 AM
TOGWT's Avatar
TOGWT
Waffle Weave Towel - a waffle (Piqué) weave towel is a synthetic micro fibre woven with a dimpled pattern, which much like an open-cell sponge provides thousands of small pockets to trap dirt or grit. The absorbency of these towels is quite remarkable; they are able to hold seven or eight times their weight in water. Instead of wiping with your waffle weave towel drying towel, blot the paint to minimize adding imperfections
Drying methodology- provided the paint finish has been rinsed adequately (See Drying a Vehicle using 'sheeting' water) there should be no dirt residue. Water is a good solvent but a very poor surface lubricator. Try using a drying aid type detailer like Dodo Juice USA Time to Dry diluted 1:1 with distilled water, which provides lubricity to the paint's surface, in tandem with a damp waffle weave towel (wet, wring and then wipe) when drying your car - this will help break the surface tension of the beads causing the water to run off, allowing the towel to soak up more, and minimise water spots while lowering the friction of the towel over the surface.
Take two waffle-weave drying towels; one soaking wet (a wet towel wicks away more water than a dry towel) and one damp. Wring out the wet towel and use it as your primary drying towel, check and rinse the towel often. Wring it out as you go, this will leave smaller wet streaks, which you can remove with your damp towel and it should leave a ‘streak’ free paint surface
This drying technique is excellent for black cars (including ‘soft’ single stage paint that show every surface mark) but look so good when they are properly detailed.
This process never includes scrubbing, rubbing or applying any pressure whatsoever. The only time that pressure needs to be applied to a paint surface is when you are polishing.
Old Mar 31, 2011 | 10:12 AM
taskmaxter's Avatar
taskmaxter
Going to try out a waffle weave towel this weekend.
On those sunny days, are folks pulling the car into the garage while it is wet to dry it off after it has been washed to keep the water spots at bay?
Just curious on others routines.
Old Mar 31, 2011 | 10:59 AM
swordsman54's Avatar
swordsman54
Yea, I pull my car into the garage to dry otherwise there will be too many waterspots. With the work it goes into cleaning a black car, I like to make it as close to spotless as I can
Old Mar 31, 2011 | 01:27 PM
Steveo47's Avatar
Steveo47
I have 3 large ones froms canadian tire (mf) a's well a's 12 from chemical guys. Both work great. With a black car, especially ours, anything that touches the paint will make very small scratches
Old Mar 31, 2011 | 01:39 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
I have a Di Tank from the company below that eliminates all the crap from your city water and results in clean water and use it EVERYTIME i wash my car:
South Coast Water
IMO, an absolute necessity for our cars. It leaves ZERO water spots, which means no drying, which means no contact after rinsing off the soap, which means LESS SCRATCHES.
Pretty affordable too.
I also have their RO system that I use for my drinking water that is A LOT cleaner than any of the bottled waters you buy.
Old Mar 31, 2011 | 02:21 PM
htran16's Avatar
htran16
^^^ really? no drying after washing your car and it leaves no waterspots?
Old Mar 31, 2011 | 02:22 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Yup.
Used by lots of detailers around here.
Old Apr 4, 2011 | 02:17 PM
Brooklynstar23's Avatar
Brooklynstar23
Here is what I do:
First I use all Chemical Guys products:
Wash and wax shampoo
CG Speed Wipe quick detailer
2 huge waffel weave towels
I wash the car like normal washing from top down but using only sponge to about the middle of the door...then i take a fresh sponge and wash from the middle of the door down all arouind the car....I rinse off the car...then while it still wet I take the CG speed wipe quick detail and spray the entire car down, everything including the windows...the neutral ph in the speed wipe will neutralize the water and will do 2 things for you 1) it buys you a ton of time in terms of drying your car since you pretty much dont have to worry about water spots and 2) it really really brings out a great shine....Once the car is sprayed down I take my 2 waffel weave towels and dry...thats it!
Old Apr 7, 2011 | 09:32 AM
Dingo6610's Avatar
Dingo6610
Originally Posted by hispeed-lowdrag
Also make sure you are sheeting the water before you start to dry, I can dry the entire g with 1 waffle weave MF towel (from detailed image of course) as long as it's sheeted
And absolutely don't wash in the sun
I'm an idiot here. What is "sheeting the water"?
Old Apr 7, 2011 | 09:44 AM
ESSRTEE8's Avatar
ESSRTEE8
Here is a great how to video from Adams.
The whole series is great.
The products they sell are top notch.
YouTube - Adamspolishes's Channel
Old Apr 7, 2011 | 09:58 AM
breftayka's Avatar
breftayka
From detailedimage.com
Sheeting Technique (Return to Top)
The sheeting method is a simple process that allows you to dry most of your vehicle without ever needing to touch the paint with a drying towel. The main idea behind the sheeting method is to create a cascading effect where the water combines with water and pulls it down, off of the vehicle. When done properly, especially on a vehicle with a sealant or wax on it, you are left with only a few drops of water on each panel, which can easily be absorbed with your drying towel.
How-To Perform the Sheeting Technique
Note: This should be performed after you vehicle has been properly washed following the recommended steps. Also, make sure your hose is dispensing free flowing water prior to starting.
  • Step 1: Starting from the top of your vehicle moving left to right, flood the roof until water is pouring off the edge
  • Step 2: Quickly lower the hose a little to "catch" the water falling from the roof, this time moving right to left
  • Step 3: Lower the hose again and continue in the opposite direction moving left to right
  • Step 4: Continue this technique until you reach the lowest panels of your vehicle
  • Step 5: Finish drying your vehicle
A lot of good info here. http://www.detailedimage.com/Auto-De...ng-and-Drying/
Old Apr 7, 2011 | 10:00 AM
breftayka's Avatar
breftayka
Can any of you experts advise me which is the better/preferred way for spraying/rinsing the car? A light electronic pressure washer or plain hose?
Sorry to butt in here, but wanted to keep the good info flowing.
Old Apr 7, 2011 | 12:03 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
^ I just use a regular hose with your typical Gilmour nozzle you find at WallyWorld or whatever.
Then, I sheet.
Old Apr 7, 2011 | 01:18 PM
  #29
breftayka's Avatar
breftayka
Then, I sheet.
I already have the pressure washer. I'm basically asking if its a bad idea lol. I had those nozzles but I always leave them outside and they break all the time.
Old Apr 7, 2011 | 02:28 PM
  #30
hispeed-lowdrag's Avatar
hispeed-lowdrag
I just use this guy for everything
Gilmour Foamaster II Foam Gun - 1/4 Gallon Tank | Detailed Image
take off the fluid tank and just use the handle to wash off, then use the hose by itself to sheet
