Help How to clean the inside of the windshield?
Old Aug 28, 2010 | 01:22 PM
sunten1's Avatar
sunten1
What is the best way to clean the inside of your windshield.
The inside of my front windshield has alot of haze on it when light is hitting it, like headlights at night....any ideas on how to remove it.
Old Aug 28, 2010 | 02:26 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
For sure man...get some of this
Stoner Invisible Glass - 19 oz | Detailed Image
And a good MF towel. I use it for the inside and outside windows (and any other glass surface) on my G
Old Aug 28, 2010 | 06:21 PM
DetailersDomain's Avatar
DetailersDomain
Window cleaning has always been a big challenge for both detailers and car washes. It’s an area where customers demand perfection, but more times than not, they are dissatisfied with the look of their glass. We all try to provide streak free and crystal clear glass, but streaking is a huge concern. We need to understand many variables that cause window streaks, have a good technique, and use quality cleaners and towels to produce perfect windows every time.
What causes streaks?
Streaks are caused by a number of things. Some are easily controlled. Some are not. Let’s take a look at the causes.
* Window cleaner- You have to be aware of what type of window cleaner you are using to avoid streaks. Many window cleaners contain a combination of ingredients that will clean, but may also cause steaks. Those ingredients may be alcohol, ammonia, and detergents. Depending on how fast or slow these ingredients evaporate and how highly concentrated they are found in the window cleaner, you may have streaking problems. The residue from these ingredients will sometimes dry and evaporate on the glass before your window towel can remove them. Window cleaners need to be properly diluted. More is not better. The higher the concentration level is of your cleaner, the greater possibility for streaking exists.
Once you know you have the correct dilution of window cleaner and you know the cleaner is not the source of streaking, there are still other areas to examine for streaks.
  • Type of towel- With so many types of towels available, it is very confusing to figure out which will be the best for window cleaning. You need a towel that is absorbent, lint free, and will actually help clean the glass. Many detailers still use terry cloth towels to clean windows, and unfortunately, these are not the best choice. Once these towels get too wet, they lose absorption and will only spread the dirt and moisture around the glass until it all evaporates on its own, leaving the glass full of streaks. These towels also leave a tremendous amount of lint. I have been searching for the best available window towel for years and still have yet to find the perfect one. However, your best choice will be a micro fiber towel in the form of a waffle weave or a 100% cotton surgical towel. I use these in combination which will be discussed later.
  • Contamination- another source of streaking can be contamination. You may have contaminated towels from a few sources. If you are using your window towels for any other purpose, they may be contaminated with other products you are using. I have seen detailers use the same towel to wipe excess tire dressing from wheels and use that exact towel to clean windows and wonder why his windows were not coming out so well! Many detailers will have towels dedicated for window cleaning only, but they will wash them along with towels that have been wiping up excess tire dressing or polish and wax. All of this residue may contaminate window towels if they are all washed together. Window towels need to be washed separate from all other towels. It is also a good idea to run them through a second rinse cycle to fully wash away any contamination.
  • Not using enough cleaner- Many detailers that I observe cleaning windows simply do not use enough window cleaner. They think that too much liquid will take too long to clean up, or they are afraid to get their window towel too wet, knowing this can be problematic later on. Consequently, their method of window cleaning is to use a small amount of cleaner and let the towel do the rest. This results in the cleaner being wiped up and dried too quickly and dirt just being pushed around the glass and not totally picked up. This will cause streaking.
  • Spraying cleaner on the towel- I also see many detailers spray the window cleaner directly on the towel. This is incorrect. By spraying the cleaner on the towel, you are letting the cleaner soak into the towel and not soak into the dirt that is on the glass. This also equates to not enough product being used and will result in streaks.
DetailersDomain
Being in hurry- many detailers simply rush the entire process. They think the glass is fairly clean to begin with, so they give the glass a quick spritz, quickly run the towel back and forth, and assume they have correctly cleaned the window. Being in a hurry also leads to poor technique which will further enhance the possibility of streaking
Window cleaning folk lore
Some people think they have magic formulas for window cleaning such as special cleaners or special towels. It is true that you need great cleaner and really good towels to clean windows. Some people have subscribed to the theory that you do not need a window cleaning towel at all.
Many people, in many window cleaning situations, used to use newspaper to clean windows with very good results. There was a reason for this. Newspaper is very absorbent and lint free. Also, it’s virtually cost free and plentiful. When a piece gets too saturated, simply grab a new sheet. It seemed to work well. But there was a logical reason for this. The newsprint, the ink used on the newspaper, used to be kerosene based. Kerosene is a terrific cleaner. It also does not evaporate very easily. So many people used to simply spray some water on a glass surface, clean and wipe it with newspaper and they produced streak free windows. However, the ink in newspaper is no longer kerosene based, so newspaper simply is not as effective as it used to be. And although it is very absorbent, it’s very difficult to hold and get flat surfaces to wipe across the glass. You generally need to scrunch the newspaper up in your hand. By doing this, it’s very easy to miss certain spots like corners. These missed spots can be streaks, or dirt and haze that never gets fully cleaned off the surface. So, in my opinion, newspaper is not a good choice of window cleaning towel.
Towel choices
Before we talk about which are the correct towels to use, let’s make sure we know what towels not to use. Paper towels are not a good choice. They are absorbent, but many people continue to use the same piece even after its soaking wet. They also will leave a lot of lint. The same also hold true for napkins, tissues, old T shirts, handkerchiefs, etc. We need to have the correct towels to do a great job.
I use a combination of different towels. We all agree that micro fiber is the best choice for cleaning. However, some micro fiber towels do not absorb water very well and this is problematic in window cleaning. A regular micro fiber towel tends to push the liquid around the glass and never get absorbed in the towel. You need a towel that not only will clean, but will also be absorbent. With that in mind, I will use a surgical towel to perform the cleaning part of the process, and I use a waffle weave micro fiber towel to use as a final buff towel to ensure any and all residue has been wiped off.
A surgical towel is 100% cotton but lint free. It’s very absorbent, but also has some bite to it, so it will dig in and clean the glass. The waffle weave micro fiber towel is much more absorbent than regular micro fiber, so it will absorb any residual moisture and also buff the glass clean.
Before you start
The first thing to look for in cleaning windows is if there is any glue residue from old decals or stickers on the glass. If so, use an older towel to remove the glue and keep your actual window towels clean. You never want any glue on your towels as that will smear all over the glass you are trying to clean.
There are some things that need to be done before you start to clean the glass. You need your towels nearby. You can’t spray the glass, walk around looking for a towel, take a phone call, have a drink, and then clean the glass. It just won’t work. You need to be ready to go.
Next, the towel needs to be folded correctly to be able to perform its job. Most towels are approximately 16×16 inches. If you fold it across twice, you will have an 8×8 towel which fits perfectly in your hand and will give you a good cushion, be more absorbent, and allow you to easily maneuver the towel around the glass.
The technique
My cleaning window towel is the surgical towel. My buffing window towel is the waffle weave micro fiber that will finish off and buff the glass.
My towels are pre-folded and ready to go. I will spray the window cleaner directly on the glass to wet and emulsify the dirt and haze that accumulates. The cleaner should cover almost all of the glass, but not start to run down the surface. Immediately after spraying the glass I will clean the glass with my cleaning window towel. First you want to box out the area and cover all 4 corners of the glass and really make sure the towel gets into those tight corners. Then you want to overlap your stokes by about 50% in either a back and forth or up and down motion and cover the entire surface. You do not want to move in a circular direction because areas may be missed this way.
If you’re cleaning towel starts to get too dirty or too wet, open up the folded towel and use a fresher side. There is no need to wipe the window totally dry with this towel. With a little moisture still left on the glass, quickly switch to your buffing window towel to absorb and buff the remaining moisture. This process may seem like extra work, but it ensures that the glass will be as streak free and as perfect as possible.
Which window gets cleaned first?
Your choice of which window to start with is totally arbitrary, but I do have an opinion and hopefully a logical explanation of where to begin.
I begin with the front windshield. This is a fairly difficult glass to clean on most vehicles because of the very pronounced slope on many of today’s cars. I prefer to start with the most difficult glass first. Plus, I know my towels are fresh and clean and this gives me the best chance at producing a streak free finish. This really is the most important piece of glass to clean because the customer is constantly looking out of the front windshield. If you mess this glass up, the customer most certainly WILL notice and will most likely start to look for other problems.
Next, I do the rear windshield because it’s the other most looked through window and also a very difficult piece of glass to clean. Many times you will have to contort your body to reach the tight areas, while also being careful not to hit the glass with your sweaty forearms. We all know the feeling of trying to clean a hot and difficult interior on a sweltering summer day. One wrong move with your sweaty arms will mean doing that part of the glass all over again. But take your time and get it right! Don’t rush! Being in a huge hurry is a leading cause of streaks. You must be able to expertly navigate around the third brake light housing and reach the towel as deep into the rear shelf as possible to get that film at the very bottom of the rear windshield.
Once the very challenging front and rear windshields are cleaned, I can now stand back up, get out of the car and clean the side glass. DO NOT forget to lower the side glass down and inch or two to expose the upper lips of the side glass. This generally is a very dirty area. After cleaning the upper lips of all the glass, I will most likely have to throw my cleaning towel in the wash basket. It’s now pretty wet and dirty and I do not want to risk re-depositing that dirt back onto the glass. So I simply discard that cleaning towel and introduce a new one to clean all the side glass. My buffing towel should not get too wet or dirty, so that towel can stay in play.
Double check
After all the glass is completed, look for streaks. It better that you find them than the customer. Examine the glass from different angles both inside and out and look for streaks. A perfect window will look like there is no window there at all.
As you can see, window cleaning is a little more involved than it looks. Many customers will base their decision to continue to use your services based on the cleanliness of their windows. Don’t let this often overlooked problem drive customers away.
To purchase glass cleaning products click here
Old Aug 28, 2010 | 08:19 PM
hispeed-lowdrag
Lol to summarize the book posted above...
Get a good cleaner (like I posted, or I'm sure Dealers Domain has some) and a high quality MF towel. Spray and wipe. Repeat.
Old Sep 27, 2010 | 12:16 PM
YeeP's Avatar
YeeP
I used to be 200% against any product used on glass in a car. In my opinion, if you had streaks after you used a chamois, it was because you used some stupid product before and it was still on the glass.
Yesterday I spent almost all day detailing my G37, and I used some CAR glass product for the first time. based on the "type of towel" post above, I guess I made some mistakes, but I have to say that the glass on this car looks awesome. For some reason, the G37 had the hardest glass to make look good that I have ever had on any car. Mine was the same as the OP where it looked great until the sun hit it right and it was terrible!
Anyway, I guess at this point I will go through this bottle and try some stuff from Detailed Image, as they have never done me wrong. I bought my stuff on a whim because I was angry at the stupid streaks.
Old Oct 5, 2010 | 09:18 AM
philter25's Avatar
philter25
Windex and a paper towel work for me.
I save the expensive stuff for my paint.
Old Oct 5, 2010 | 09:23 AM
hispeed-lowdrag
Be careful, if you have any tint Windex can possibly damage it.
And the stuff I use from detailed image is like $9.95, not expensive at all and it lasts forever
Old Oct 5, 2010 | 11:02 AM
TheIvoryG's Avatar
TheIvoryG
I think the key to windows is having two towels. I too use Stoners, but any solid cleaner made for tint will do. I spray, then wipe with my first towel that has a higher nap. Usually looks sort of like it is just moving around the moisture. Keep wiping until it starts to dissipate, then bring in a much lower nap towel(glass towels are fine...but I honestly rarely use them. Just something with really low nap) and clean up the rest. By basically buffing in this last step, you will get the window fully dry, streak free, and not leave any lint.
Windex = bad. Will ruin your tint.
Paper towels = bad. Breeding ground for lint.
Old Jan 20, 2011 | 04:28 AM
tony_m_777's Avatar
tony_m_777
Windex's new formula, Window Auto Glass Cleaner is a great product for cleaning the car window's, plus it's safe on tinted windows. The best part of it all is it's more affordable then all the other glass cleaning solutions out there.
Originally Posted by TheIvoryG
Windex = bad. Will ruin your tint..
Old Jan 20, 2011 | 12:06 PM
123u's Avatar
123u
clean it with a microfiber you should all set.
Chemical Guys Window Clean - 16 oz | Detailed Image
Old Jan 20, 2011 | 11:58 PM
Bo2point0's Avatar
Bo2point0
I only use water and elbow grease
3 towels.
first, damp wipe
second, wipe dry
third, wipe clean and extra dry
Takes time and a lot of elbow grease
I also never touch my windows or windshield, also when I sneeze I cover up my mouth (left hand) and look to the side if possible to avoid snot splash on any glass/materials.
Left hand because it does not touch shifter or many things in car.
Then again when I fart in my car I roll the window down so it wont soak in anything. I'm paranoid.
Old Jan 21, 2011 | 10:16 AM
maxximase's Avatar
maxximase
For the last 10 years, I've used nothing but Sprayway and paper towels and I never get streaks. All my cars have had tinted windows. The paper towels do leave some lint behind if used too much, so I typically do 1 towel/window.
Old Jan 21, 2011 | 06:19 PM
TVPostSound's Avatar
TVPostSound
+1
Costco sells those in 6 packs!!!
Never streaks.
Old Jan 28, 2011 | 02:18 AM
roots4x's Avatar
roots4x
The most annoying thing is cleaning the glass at the edges. That $10 "as seen on TV" product that looks like a mini Swiffer works extremely well, although it is also of extremely poor quality.
