Help Touch up paint...
Old Nov 24, 2009 | 11:29 AM
gicode0823's Avatar
gicode0823
Touch up paint...
When I bought my G37 used from Infiniti Dealership, they "tried" to cover up the scratches by using touch-up paint...
BUT they put so much of touch-up paint on the scratches that it actually above the paint level surfaces....
here is one of the scratch that is covered with touch-up paint
Bigger picture here: http://farm3.static.flickr.com/2547/...cb7e0a16_b.jpg
Is there anything I can do using polish?
Old Nov 24, 2009 | 11:37 AM
Aaron's Avatar
Aaron
If you have any experience, wetsand it with 2000 grit and then buff.
If not, take it to a reputable body shop.
Old Nov 24, 2009 | 11:47 AM
gicode0823's Avatar
gicode0823
able to buff out using pcwith medium cut polish?
Old Nov 24, 2009 | 11:50 AM
Aaron's Avatar
Aaron
I'd be worried about the surrounding paint
Old Nov 24, 2009 | 11:59 AM
wakeboardr116's Avatar
wakeboardr116
Was this on a new car? I would have never accepted the car with scratches like that and would pass and try to find another one.
If you have some experience wet sand and buff should do the trick, otherwise take it to a pro.
Old Nov 24, 2009 | 12:20 PM
I'd try compound, cutting, then finishing polishes first to see if that corrects it sufficiently. A rotary will do much better than a PC, but not if you're inexperienced with it because you'll make it worse. If you aren't happy with the results of polishing alone, then I'd try the wet sanding and polishing. Only attempt wet sanding if you know what you're doing.
Old Nov 24, 2009 | 02:50 PM
gicode0823's Avatar
gicode0823
you wanna try it black betty? =D I have no experience using wet sand... I would try it if i had like piece of metal painted in same condition but too scared to mess my paint with my experience... lol
I know you have alot more experiences than I do...
Old Nov 24, 2009 | 03:03 PM
Is this the only touch up spot you have on the car? If not how many? Do you want me to just correct the touch up spot or detail the whole car?
I'll take a look at it in persona and see what I can do for you. I won't be able to make it perfect, but I can certainly make it look better than it does now. It will have to be next week though, probably going out of town for the holidy.
Old Nov 24, 2009 | 07:58 PM
rAvi665's Avatar
rAvi665
U shud take it back to the dealership and b*tch about it.
Old Nov 25, 2009 | 09:40 AM
G Girl's Avatar
G Girl
DON'T take it back to the dealership!!! They will only make it worse.
Old Nov 25, 2009 | 05:00 PM
gicode0823's Avatar
gicode0823
I have final next few weeks...
maybe i will buy compound and see what happens
much safer than wet sand correct?
Old Nov 25, 2009 | 05:33 PM
Compounding with a PC is safer than wet sanding. You may leave a haze on the black paint, but going back over it with a cutting then a finshing polish will get rid of the compound haze. If you can correct it without wet sanding, do it.
Old Nov 25, 2009 | 10:23 PM
rAvi665's Avatar
rAvi665
The dealership usually works with people that repair deep scratches and dent for cars on there lot. When I got my car it had a deep scratch on the front bumper and they said they'll take car of it. When I received the car I cudn't even find a blemish where the scratch was. Talk to them usually they have someone they work with or go to a different dealership and ask them.
Old Nov 26, 2009 | 06:45 AM
shumby's Avatar
shumby
tru using dr. color chip on it. it will not be 100% but it will be better tne a paint pen
Old Nov 26, 2009 | 11:27 AM
gicode0823's Avatar
gicode0823
any recommendation on pads and compound?
