What is the best cleaner for Clear Bra?
Bird droppings, dirt residue, and hard water marks on my Clear Bra Hood. What can I use to get them off? I've tried clay, plastic polish and vineger, still doen't work. WTF do I need to do???
Clean with normal car wash soap when you wash your car. Do not use any bug removers or other cleaners. Following the wash and dry, clean/polish with Plexus. It is a plastic cleaner and conditioner.
George from DetailedImage carries it.
Link: http://www.detailedimage.com/Plexus-...otectant-P109/
Hook it up. It's the best there is.
You can use wax on a ClearBra, however, it is not recommended you use any abrasives or other polishes that would normally be used to remove swirls or other paint imperfections.
I would also recommend you use some painters tape along the edges when waxing around Clear Bra. The excess that dries on the edge can be difficult to remove.
Clear Bra installers recommend you treat the film similar to paint so yes, wax it.
A sealant is fine. You just don't want to use an abrasive as it can dull the finish. The abrasive will essentially rub and dull the finish similar to using a brillo pad on something (not to that extreme though).
Sealant, plastic polish, Plexus, vinegar...Nothing is getting rid of hard water marks. Jesus! Any other recommendations out there?
Hmmm.. Interesting. Never heard of anyone getting hard water spots on CB... Did you try a Clay Bar? Not sure if it would help, but worth a shot.
Does that help?
Some examples of polishes with abrasives are:
1) Poorboys SSR Line
2) Menzerna PO106FF
3) 3M Perfect-It
4) There are many others... If they claim to remove swirls, it likely has an abrasive.
I have a question about gloss polishing. After I install a clear bra on and gloss polish my car (Zaino products), will the area with the clear bra look different than the area I apply layers of gloss polishing? I'm afraid my car would look weird after polishing it because I can't polish the area with the clear bra.
Thanks in advance!
Rai
Thanks in advance!
Rai
best way to get rid of bug stains/bird poop stains is with a heat gun. just be careful or you'll mess up the clear bra. that's what i used to get rid of the stains after my road trip to los angeles.
you can also use the heat gun to remove fine scratches on the bra.
