Ask a Professional Detailer... Brought to you by Detailed Image
Old Mar 31, 2008 | 06:27 PM
  #436
infidsg35's Avatar
infidsg35
Ok you asked for it lol...
1. My car is only 2 months old so from what I read I still need to claybar as a first step.. Is this true?
2. Since my car is only 2 months old do I really need something as abrasive as SIP or IP with orange pad? The paint looks good and feels smooth but I am starting to see swirls all over. There nothing crazy just enough to make me crazy! Damn dealer!!! LoL
3. I looked at the PC polisher on your site and saw that you have a starter kit. I know you need the backplate to use pads but why the 6 inch counter weight?
4. Are the pads easy to clean or should you just order new ones with each use?
5. Is there any advantage to apply/take off polish/wax with the RO Polishers? I would usualy put on and take off by hand...
6. I plan on washing, clay barin, washing, polishing (undecided if this needs to be a 1 or 2 step), then Z5 2-3 times and Z2 1-2 times, wait 24 hours and wax with Natty Blue, fallowed by a gloss enhancer Z-6-Z-8.. This sound good? Keep in mind I love Zaino products espically sealents.
7. Does Natty Blue add more protection/look better with multiple coats?
8. As far as washing I think im going to go with the 2 bucket 2 glove method with grit guard. Seems to make the most sense to me.. Im not going to go for the RO water filter its pretty expensive plus the coast of use is high with filter refills.. Maybe Ill get 2 gallons of destilled water and pour down my car...
Ok im done for now.. Thanx for the replys I will def order what I need that you have from your site!
Old Mar 31, 2008 | 07:25 PM
  #437
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
I recommend claying new vehicles. During the transit of your vehicle, it could have traveled via boat, truck, train, etc. it becomes exposed to elements, rail dust, pollution, and much more. By claying you're vehicle, you'll remove the embedded contamination and allow your polishes, sealant and wax to perform it's best.
Depends on how deep the swirls are, can't really say without a picture of the imperfections. Whether you use it now or in the future, it's nice to have a more aggressive polish option handy because sooner or later you'll get someone who dings you in a parking lot, with a shopping cart, etc.
The counter weight helps cut down on vibrations from using a 6" backing plate, like the one we sell. The PC will still vibrate, but slightly less with the appropriate counter weight. Less vibrations = a less tired arm and slightly longer durability from your PC.
New pads each detail would become very expensive! If you use the pads properly, they are very easy to clean. When polishing, I use about 3 pads per coat, swapping them out about 1/3rd of the way through the vehicle for a fresh one. By doing this you help keep the consistency of your polishing and prolong the life of your pads. The other alternative is to take a brush, like a toothbrush and after every panel or so, try to clean out the pads as best you can by running the buffer on the brush. The cleaner the pad the better your polish will perform and the better your results. Many detailers use 1 pad per coat and wonder why at the end the results aren't as good as when they started. A saturated pad can diminish results.
Nope, you'd only create more problems if anything. The bonnets some places sell to put on top of the pads are not effective and you can't exactly reach every area of the vehicle. Again, I use about 3 - 4 clean microfiber towels per coat I remove when I detail, so imagine how many bonnets would be needed, considering you can fold a MF towel into 1/4th's and effectively get 8 clean sides out of it.
Sounds like a great plan.
I find that 2 - 3 coats spaced at least 12 hours apart (waxes usually have shorter cure times than sealants) achieves maximum results. Beyond 3 coats, you reach a point of diminishing returns. Protection wise, the added protection is pretty minimal, but you'll achieve more of an even coverage and enhance the depth and gloss a little bit.
Thanks for the support. You've been asking some great questions and know your detail will be a success. If you have any other questions, let me know.
Regards,
George
Old Mar 31, 2008 | 08:44 PM
  #438
infidsg35's Avatar
infidsg35
Ok here some more
1. How do you clean the pads? You mentioned the tooth brush but that more during the detail how about when you are done? Im sure you need to get all polish of so it doesnt dry/cake on...
2. Ok so microfibers make good polish/wax/sealent removers can you wash these after detail? If so what would be proper steps?
3. Ok we talked about clay/sealents/waxes what about glaze? What exactly is it and where does it belong in the detail process if anywhere?
Thank you for all the advice! Im sure it will be a sucess too with all this knowledge I might be dangerous tho!!!
Old Apr 1, 2008 | 12:10 PM
  #439
RedlineSi's Avatar
RedlineSi
Hey George, what do you recommend for polishing exhaust tips? I see you have two different products. Anyone you recommend over the other?
Old Apr 1, 2008 | 12:52 PM
  #440
Detailed Image
Ok here some more
I let them soak in a 5 gallon bucket with some Snappy Clean solution. It's a citrus degreaser that helps remove product from the pads. I massage the pads with my thumbs while they are soaking to get as much product out, then let them air dry. After they are dry, I recommend storing them in Ziploc bags so dust and debris doesn't settle onto them. I usually dry them face down on a towel or something absorbent.
Here's a thorough writeup on how to properly care for your microfiber.
Glaze comes in between polishing and sealing. What it's designed to do is add a layer of depth and gloss, while filling in some minor imperfections. Personally, I recommend our customers spend more time on the polishing stage as those results are permanent rather than temporary from a glaze, but a glaze has it's place. I recommend using one on show cars, lighter colored vehicles to get additional pop, special occasions or if you're just going for the absolute best finish. I have a new glaze coming in at the end of the week that works well under sealants. Certain glazes, usually ones with more oil than clay, can hinder the bonding of a sealant onto the paint, which is part of the reason I don't recommend them all the time.
Either one works well, they are very similar to be honest. I usually go to the P21S Finish Restorer for whatever reason. On exhaust tips, for some more cut, you can apply the metal polish with some 000 or 0000 grade steel wool, then apply your final application with a foam applicator pad or microfiber towel to restore the gloss to its fullest. I'd recommend removing the tips from the vehicle if it's easy to do so.
Old Apr 1, 2008 | 02:12 PM
  #441
infidsg35's Avatar
infidsg35
^ you hit the nail on the head on how to restore exhaust tips... See metal polishing I do know about LOL.. Many motorcycle frames done by hand..
Depending on how bad they are with rust/dirt/carbon ect. If not to bad then like George said wash tips well with soap and water, then use WET 000 grade steel wool fallowed by 0000 WET steel wool. Then rinse off tip and dry them. Then use Mother Bullit Aluminum polish and work it in with a applicator till you get the finish you want.. If you still arent happy then you may need to start wet sanding with 1500 grit then 2000 grit fallowed by some compound metal polished then start with the steel steel wool and polish.. Hope this helps!
George ill be placing an order today or tomorrow is the 10offG37 still work? Thanx
Old Apr 1, 2008 | 02:37 PM
  #442
RedlineSi's Avatar
RedlineSi
One last thing. What is the best way to care for the sheepskin mitts? I used them this weekend and just rinsed them out and ringed them out and let them air dry. Is there anything in particular I should do?
Old Apr 1, 2008 | 04:47 PM
  #443
Detailed Image
Nope, letting them air dry is the best way to preserve maximum durability. Not sure if you got our latest round of mitts, but our new ones have a leather hoop on them specifically to hang them up with.
Regards,
George
Old Apr 3, 2008 | 06:39 PM
  #444
YeahRightFoo's Avatar
YeahRightFoo
Hey George,
I need some advice regarding removing tree sap. I was able to remove tree sap on the body of the car, but for some reason on the windshield the tree sap will not come off. Do I have to scrap it? If so what would I use to not damage the windshield? I am scared of messing up the glass.
Thanks.
Old Apr 3, 2008 | 07:39 PM
  #445
Detailed Image
Originally Posted by YeahRightFoo
Hey George,
Thanks.
You're lucky it's the glass you're having trouble with. I typically mist some quick detailer solution and use a straight blade razor on it. Work it at an angle similar to the slope of the glass and you don't have much to worry about. The quick detailer (or just some auto shampoo and water) acts as a lubricant and helps glide the blade across the glass. I've been doing this for years and haven't had any issues with it scratching the glass.
Hope this helps.
George
Old Apr 5, 2008 | 04:48 PM
  #446
Taktix1's Avatar
Taktix1
George,
Ive purchased a few MF towels from you to use for quick detailing. After I'm done with them and it really isnt a big enough load to throw in the wash what should I do with them? I know that you arent supposed to let the product dry on the towel so what I've been doing is just soaking them in a bucket of water until I use enough to wash them, sometimes leaving them in the water for days. Any thoughts?
Old Apr 5, 2008 | 08:44 PM
  #447
GregUMR's Avatar
GregUMR
two questions;
how do i clean and dry the waffle mf towel i bought from you
how do i clean and dry my sheepskin wash mit i got from you.
sorry for no punc. and being brief, im on a phone
Old Apr 6, 2008 | 01:38 AM
  #448
infidsg35's Avatar
infidsg35
Ok I just ordered! WoW I just kept adding things to the shopping cart like nothing ha ha. Im going to do a 2 step as my car looked like crap today in sun I hope the stuff you recomended is as good as you say it is.. I went with IP and P0106FF and Orange and white pads... I will take before and after pic's.. Thanx again!
Old Apr 6, 2008 | 10:55 AM
  #449
Detailed Image
Originally Posted by Taktix1
George,
You're doing the best thing possible for your towels. After any use, you should let them soak in water ASAP. You don't have to necessarily let them soak for days, but I'm sure it's ok. You could probably wring them out and let them begin to air dry if they are getting in the way, then just wash them when you have enough as you said.
Originally Posted by GregUMR
two questions;
Here's a complete guide on how we recommend caring for microfiber products.
Rinse with cool water from your hose or whatever to help release contamination, then let it air dry. If you have one of our latest sheepskin mitts they have a hoop near the cuff, perfect for hanging them.
Keep us posted, you should be quite pleased with the results. If this is your first time using a buffer, I recommend doing some research, like reading our polishing guide or searching for some video demonstrations. The more you use the buffer, the better you'll be at it. Let me know if you have any questions on anything.
George
Old Apr 6, 2008 | 10:04 PM
  #450
infidsg35's Avatar
infidsg35
Hey do sealants go bad? I have a bottle thats 2 years old and one that 1..
