Canada Serving Canada.
my winters - 18" BSA 264's & blizzak's
Old Oct 11, 2008 | 02:44 PM
Ru5tY's Avatar
Ru5tY
Found a set of winter rims from a former G35 owner that fit the G37S!
18x8 BSA 264 rims with Blizzak LM-22's, used for 2 winters.
Originally I was going to buy these rims new, but got real lucky on kijiji and got a good deal for $1,000
However, the tires are a bit smaller than the ideal size though - thats why the wheelgap looks bigger than they're supposed to be. (tires are 225/45R18, instead of tirerack's recommended 225/50/R18)
The version I have are 40 offset, but apparently the 24 offset version works also. The 40 offset version fits inside the wheel well a little bit though.
There's about 1 cm clearance for the brakes. (8mm to be exact)
FYI, if any of you guys are in Toronto and need a good deal, the best I could find locally was the RFD groupbuy with Simply Tire (http://www.redflagdeals.com/forums/s...d.php?t=639602). I was quoted $620 for the 18" BSA 264's, and $760 for Hankook W300 in 235/50R18 (not including tax, so it works out to around $1500 all in, and there's a groupbuy discount of $50 on top of that).
Now I'm ready to drive to Tremblant this winter!
Old Oct 11, 2008 | 02:49 PM
nogoodname's Avatar
nogoodname
those are not bad looking rims, you got lucky, 1000 for all of it.
Old Oct 11, 2008 | 02:58 PM
aliiin's Avatar
aliiin
BMW Defector
not bad for winter rims
Old Oct 11, 2008 | 03:02 PM
shumby's Avatar
shumby
so total set up was 1500?
Old Oct 11, 2008 | 03:04 PM
nogoodname's Avatar
nogoodname
1500 for all new stuff, he got it for 1000 cash dollars used on kijijijijijijijijijiji
Old Oct 11, 2008 | 03:15 PM
Ru5tY's Avatar
Ru5tY
Yep, $1000 on kijiji for 18" rims and blizzak's (used for 2 winters, but plenty of tread)
Before I found the used deal, I was pretty much set on getting those same rims and hankook W300's, both new for $1500 all in. if substitute for blizzak LM-25's, it would've been $1800 all in.
No TPMS in any of these prices listed. I think I can live without 'em!
Old Oct 11, 2008 | 10:17 PM
Nighthawk26's Avatar
Nighthawk26
Glad you posted pics. I just picked up the EXACT set from kijiji myself but with Pirelli tires, used one winter, same ofset as well. My car is ALSO white so great to see them on there. I snagged them for $750 though!
I knew the 40 offset would be tucked a bit, thanks for the details!
Old Oct 11, 2008 | 11:15 PM
Ru5tY's Avatar
Ru5tY
Wow, that's a hot deal!
BTW i drove around the block with 1 of the rims mounted on and didn't feel any vibrations - but I didn't have a chance to test it out at highway speeds though. I ended up getting a set of hubcentric rings anyways, just in case of potential vibrations.
I also went from a TL to the G37
Old Oct 11, 2008 | 11:56 PM
NIGHTLFEphantom's Avatar
NIGHTLFEphantom
i'm glad to see i'm not the only one who is in need of a winter set up.. i still need 18" tires and rims before november hits!!!
Old Oct 12, 2008 | 01:11 AM
PSYH's Avatar
PSYH
Post Whore
Hey, I went to Wheels Direct last year and they quoted me those rims with LM-25s for a whopping $2100. I pointed at the guy and laughed in his face (not really) and got better rims with LM-25s for $300 less. Too bad when I got the car it was already January and (new or used) snow tires/wheels were scarce.
Good deal, rusty!
Old Oct 12, 2008 | 02:44 PM
da mayor's Avatar
da mayor
sick deal i need to order some of those. looks good for 18s
Old Oct 12, 2008 | 03:04 PM
Loki123's Avatar
Loki123
Are most putting 225/45's on the front and 245/45's on the rear?
Old Oct 12, 2008 | 03:15 PM
nogoodname's Avatar
nogoodname
I think some are putting 225/45/18 all around
Old Oct 12, 2008 | 08:26 PM
Nighthawk26
225/45/18 are all around on mine. Just saw on here before I grabbed them that lots of people were running them.
Old Oct 12, 2008 | 10:32 PM
Ru5tY's Avatar
Ru5tY
tirerack recommends 225/50R18 all around
most local shops recommend 235/50R18 all around
I've got 225/45R18, but that's not an ideal size as it's about 3% smaller circumference compared to the OEM circumference. I'll probably switch to 235/50R18 when I need new tires, as there are more choices in that size. 225/50R18 is only Blizzak LM-25's.
