CZP Soul Function Sale!
Old Jun 9, 2017 | 07:16 PM
sales@czp's Avatar
sales@czp
Hey Guys, CZP is having a sale for all of Soul Function's Suspension and Chassis Braces for the Infiniti V36 and CV36 Chassis!
_________________________
Soul Function Front Strut Tower Brace Bar - Infiniti G35 07-08 Sedan, G37 09-14 & Q40 2015 Sedan V36 / G37 08-13 & Q60 14-15 Coupe CV36
Soul Function’s Front Strut Tower Bar for the Infiniti G35/G37 is designed to maintain front suspension geometry by reducing strut tower flex. This increases the rigidity, feedback and predictability during hard cornering.
The polished bar is made from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. This design maintains strength while reducing overall weight. End brackets are powder coated with the signature Soul Function Teal.
All hardware is included and installation can be completed with simple hand tools.
Fitment:
2007-2008 Infiniti G35; Sedan; RWD & AWD
2009-2014 Infiniti G37; Coupe and Sedan; RWD & AWD
2014-2015 Infiniti Q60; Coupe; RWD & AWD
2015 Infiniti Q40; Sedan; RWD & AWD
Soul Function Front Subframe Lateral Braces - Infiniti G35 07-08 Sedan RWD, G37 09-14 RWD & Q40 2015 Sedan RWD V36 / G37 08-13 & Q60 14-15 Coupe RWD CV36
Soul Function’s Front Subframe Lateral Braces for the Infiniti V36 Chassis is designed for the rear-wheel drive sedan and coupe. These braces come standard on all-wheel drive models, however, is not included on rear-wheel drive models. This kit reduces front-end lateral flex to improve steering response under extreme cornering and rapid transitions.
These braces are constructed from aircraft grade T6061 Aluminum Alloy and are internally reinforced with multiple I-beams. The braces are powder coated with the signature Soul Function™ Teal.
This kit is designed to be fully compatible with all other Soul Function™ braces.
Fitment:
2007-2008 Infiniti G35; Sedan; RWD Only
2008-2013 Infiniti G37; Coupe, Sedan & Convertible; RWD Only 2011-2012 Infiniti G25; Sedan; RWD Only
2014-2015 Infiniti Q50; Sedan; RWD Only
2014-2015 Infiniti Q60; Coupe; RWD Only
2015 Infiniti Q40; Sedan; RWD Only
Soul Function 4-Point Front M Brace - Infiniti G35 07-08, G37 09-14 & Q40 2015 Sedan RWD V36 / G37 08-13 & Q60 14-15 Coupe RWD CV36
Soul Function’s 4-Point Front M Brace for the Infiniti V36 Chassis improves front-end stability by fortifying the subframe and the chassis. The increased rigidity allows for crisp feedback and keeps the vehicle planted during hard cornering.
The 4-Point brace is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. The brace is powder coated with the signature Soul Function™ Teal.
This product is designed to be fully compatible with all other Soul Function™ braces. This brace is designed to fit both stock and aftermarket exhaust systems.
Fitment:
Soul Function Front Fender Braces - Infiniti G35 07-08, G37 09-14 & Q40 2015 Sedan V36 / G37 08-13 & Q60 14-15 Coupe CV36
Soul Function’s Fender Brace for the Infiniti V36 Chassis reinforces one of the most critical areas of the chassis. The increased front-end frame rigidity allows the suspension to do its job more effectively and greatly improves steering feedback and predictability.
The Fender Braces are constructed from structural carbon steel so you can be confident they will withstand everything you can throw at them. The stamped and welded design maintains strength while reducing overall weight. These braces are powder coated with the signature Soul Function™ Teal.
These braces are designed to be fully compatible with all other Soul Function™ braces.
Fitment:
2008-2013 Infiniti G37; Coupe and Sedan; RWD & AWD
2011-2012 Infiniti G25; Sedan; RWD & AWD
Old Jun 9, 2017 | 07:17 PM
sales@czp's Avatar
sales@czp
Soul Function Rear Tie Bar - Infiniti G35 07-08 Sedan, G37 09-14 & Q40 2015 Sedan V36 / G37 08-13 & Q60 14-15 Coupe CV36
Soul Function’s Rear Tie Bar for the Infiniti V35 Chassis, Infiniti V36 Chassis and Nissan 350Z stiffens the rear subframe by connecting the left and right lower control arms. The result is improved handling and steering response.
The Rear Tie Bar is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. This design maintains strength while reducing overall weight. The bar is powder coated with the signature Soul Function™ Teal.
Installation can be completed with simple hand tools and stock hardware. Wheel alignment is required after installation of the Rear Tie Bar.
Fitment:
2003-2008 Nissan 350Z
2003-2008 Infiniti G35; Coupe and Sedan; RWD & AWD
*Does not fit models with 4 Wheel Active Steer (Rear Active Steering)
Soul Function 6-Point Rear Subframe Brace - Infiniti G35 07-08 Sedan RWD, G37 09-14 RWD & Q40 2015 Sedan RWD V36 / G37 08-13 & Q60 14-15 Coupe RWD CV36
Soul Function’s 6-Point Rear Subframe Brace for the Infiniti G35/G37 (V36) connects the rear subframe to multiple points of the chassis to help reduce overall vehicle body flex. This kit includes a Stainless Steel Crossmember Brace that replaces the thin OEM stamped plate.
The 6-Point Brace is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. All components are powder coated with the signature Soul Function™ Teal.
Fitment:
2008-2013 Infiniti G37; Coupe & Sedan; RWD & AWD
Soul Function 4-Point Front D Brace - Infiniti G35 07-08, G37 09-13, G25 11-12, Q40 15 Sedan / G37 08-13, Q60 14-15 Coupe V36 CV36
Soul Function’s 4-Point Front D Brace for the Infiniti V36 chassis and Nissan 370Z improves front-end stability by fortifying the subframe and chassis. The increased rigidity allows for crisp feedback and keeps the vehicle planted during hard cornering.
Fitment:
2009+ Nissan 370Z
Soul Function Rear Lower M Brace - Infiniti G35 07-08, G37 09-13, G25 11-12, Q40 15 Sedan / G37 08-13, Q60 14-15 Coupe V36 CV36
Soul Function’s Rear Lower M Brace for the Nissan 370Z and Infiniti V36 Chassis improves back-end stability by connecting the area where the rear toe arms attach to the subframe. Paired with our Rear Tie Bar, this brace helps tighten steering response and improve handling.
The Rear Lateral Arm Brace is constructed from aircraft grade T6061 Aluminum Alloy and is internally reinforced with multiple I-beams. The brace is powder coated with the signature Soul Function™ Teal.
This brace is designed to be fully compatible with all other Soul Function™ braces.
Fitment:
2009+ Nissan 370Z
Old Jul 25, 2017 | 03:07 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Aug 15, 2017 | 04:28 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Sep 8, 2017 | 06:00 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Oct 18, 2017 | 01:15 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Nov 21, 2017 | 02:21 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old May 25, 2018 | 11:29 AM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Jan 4, 2019 | 04:43 AM
jpowersjr2's Avatar
jpowersjr2
Any deals going on?
Does the rear lower m brace work with aftermarket exhausts?
Thanks!
